Previous in Forum: Pit Standard   Next in Forum: Lightning Protection
Jacking Pad
11/06/2019 9:59 AM
Dear sirs,
Where in transformer does a jacking pad fits?
Regards,
Anonymous Poster #2
Re: Jacking pad.
11/06/2019 10:25 AM
Wherever it says on the drawing.
Re: Jacking Pad
11/06/2019 12:48 PM
Four locations equidistant from the center of gravity on the outer perimeter encompassing the bulk of the total weight of the transformer....
Re: Jacking Pad
11/07/2019 2:44 AM
On large transformers the jacking pads are welded integral to the tank at time of manufacture usually on each corner or beside a corner. The sty for jacking is built up from the ground or concrete transformer plinth, out of blocks of hardwood timber formed into a criss cross pattern with the top blocks being placed to spread the load.
The jacking is done in incremental lifts with the rise being followed with packing so minimal lift is undertaken without backup timber to negate problems caused by a jack failure.
If you are referring to detachable jacking pads then their placement needs to be installed with consultation with the transformer manufacturer to ensure safety is not compromised.
Hare today, goon tomorrow!
Re: Jacking Pad
11/07/2019 4:02 AM
Some <...transformer...> units don't need them.
Size is important. Especially in hanging wallpaper.
Re: Jacking Pad
11/11/2019 3:46 AM
On the perimeter, of course, on all supporting parts
Anonymous Poster (1); Liam578 (1); PWSlack (1); SolarEagle (1); Stef (1)
