Previous in Forum: HRC Fuse Blow   Next in Forum: Require knowledge of fuji frenic invertet
Cover Block Preparation
11/16/2019 12:50 AM
Dear sirs,
How can we make standard cover block to be used for say 5 cm concreting? We made one with 1:4 cement/sand but it got crushed.
Regards,
Re: Cover block preparation.
11/16/2019 1:49 AM
Well first you need the proper type of cement, and you need probably a 50/50 mix of cement to sand, and some ~3/8" aggregate and possibly some superplasticizer...
https://www.concreteconstruction.net/how-to/various-thickness-overlay_o
11/16/2019 6:10 AM
Insufficient information.How much weight?Area of contact?Anything can be crushed.
Re: Cover Block Preparation
11/17/2019 2:43 AM
For this sort of cover block I always make the following mixture 3 gravel of a size suitable for the thickness of the cover, 2 river sand, 1 cement. Preferably the cement is good Portland cement not the stuff loaded with fly ash and include mesh in the cover.
Keep the cover moist for at least 7 days to slow the curing and prevent cracking. When cured correctly this will form a waterproof high strength concrete.
More cement can be added in moderation to increase the MPa of the concrete and go easy on the water because a sloppy wet mix will have a lower compressive strength.
Hare today, goon tomorrow!
Good Answers: 804
11/18/2019 8:09 AM
How is this related to Electrical Engineering?
11/18/2019 1:35 PM
Probably the cover for an electrical vault and many of the responses are positively shocking.
11/19/2019 10:49 AM
Good grief...
HiTekRedNek (1); Jpfalt (1); JRaef (1); PWSlack (1); SolarEagle (1); Stef (1)
