Previous in Forum: Self Adjusting Platform   Next in Forum: Hydraulic Motor to Operate Saw Blade for Brush Clearing
9 comments
Popular Science - Weaponology - New Member India - Member - New Member
Heat Exchanger / After Cooler for Blower
12/16/2019 1:29 AM
Hi...
I am currently looking for after cooler for blower. I have option of finned type and shell n tube type after cooler. As per previous exp. considered Finned type is most suitable.
But client is insisting on Shell n tube..
The air flow is @ 9000 m3/hr and 3500 m3/hr @ 700 mbar pressure.
Temp . reduction required = Dt= 70Deg. centi.
Cooling fluid is tap water.
As per calculation size of after cooler seems big.
Also, considering airflow is it advised to use shell n tube?
Pl. advice.
Pathfinder Tags: after cooler
Re: heat exchanger / after cooler for Blower
12/16/2019 2:42 AM
The temperature seems high for such a low pressure, what is the source of the makeup air? What is the air used for? Is the client looking for humidity reduction as well?
Good Answers: 137
12/17/2019 4:38 AM
He didn't give the in/out temperatures, only the reduction.
12/17/2019 5:28 AM
That might be roughly inferred, though. Say tap water 20ºC, approach say 5º = 25º, reduction of 71ºC = 96ºC initially.
Good Answers: 137
12/17/2019 9:42 AM
I just meant we can't judge the discharge temperature as high if we haven't been given it, only the desired reduction over the cooler.
For those sorts of flow (presumably 2 different systems) it's likely to be Roots blowers, and from my data for 3500 m3/h and 700 mbar pressure rise, temperature rise is ~ 70°C. More data needed on the cooling water temperature and flow available to design a cooler, whichever type OP goes for.
12/23/2019 1:44 AM
hi,
yes the application is for Roots Blower Discharge air cooling.
Outlet temp. of Roots Blower air is 120 Deg.C. Desired temp. after cooling is 50 Deg. C.
Inlet Water available for cooling at 30 Deg. C.
Cooling water is to be supplied through water pump for necessary flow requirements.
My primary guess is @ 80 -90 lpm for @ 3500 air flow.
And @ 150 lpm for 8600 air flow. considering CS tube material for Exchanger.
Re: Heat Exchanger / After Cooler for Blower
12/16/2019 11:56 AM
You need to asked why shell and tube? I’ve design regenerator for hot gases, using 2” shell and tube, but that deals with a higher flow rates... as well as plate heat exchangers.
The flow rate you have, a dimple plate heat exchanger would do the job being more efficient and cost effective.
What is the air quality passing through it? Is it dirty exhaust with high particulates?
12/23/2019 1:45 AM
hi,
air passing is atmospheric air after filtration.
12/17/2019 11:50 AM
If your client is insisting on shell-and-tube then you don’t have any options, Mildred. Simply provide your client with whatever he is prepared to pay for, and stop arguing with yourself and others. All that does is waste everybody’s time.
Good moaning!
12/23/2019 1:47 AM
yes. exactly... i am doing the same now
Register to Reply 9 comments
Codemaster (2); Crabtree (1); phoenix911 (1); sanjaykangralkar (3); SolarEagle (1); Tornado (1)
