Previous in Forum: SS Weld rust stain removal   Next in Forum: Paper Washer
Rubber seals approx rejection rate data
10/24/2007 11:00 PM
Hi All,
Please any body can provide the info on the approximate rejection rate of Rubber seals like O-rings,gaskets,membranes in any kind of application.
May be data on failure before the inteded time of functioning or failure at DOA(Death on arrival) will helpful.
Regards
Re: Rubber seals approx rejection rate data
10/26/2007 9:54 AM
Your question cannot really be answered.
I was a Distributer for "PARKER O-Rings & Seals".
During all those years we never received a single defective seal or O-ring.
Seals and O-rings are designed out of different materials in order to have the maximum life in a certain application.
90% of seal failures were due to: Improper installation; fluid incompatibility; gross contamination, (dirt); or heat.
The other 10% was just plain wear after years of service.
If you are having problems with seals I would suggest that you change suppliers or discuss your application with their engineer, (the engineering is normally free,).
Reply to Forum Thread
