Previous in Forum: Rubber seals approx rejection rate data   Next in Forum: Tire Pressure Monitoring mandated by BIG government.
12 comments
Paper Washer
10/25/2007 3:45 AM
Hi all, I am manufacture in China and I was machining the split casing for USA. When boring the holes such as bearing hole or wearing hole, we have to put a paper washer in the split surface. You know that customer will put a piece rubber seal when assembling.
But we can not get 0.76mm paper with the same performance in China and have to purchase in the USA. Is there someone who knows where we can get the paper washer as the following picture?
Thanks,
Tony
Cast,Forge,Weld,Machining,Screw,Nuts,Valve,Pump
Re: paper washer
10/25/2007 3:50 AM
The following picture is the split casing.
Re: paper washer
10/25/2007 3:53 AM
The paper washer will be putted in the split surface.
United Kingdom - Member -
Re: Paper Washer
10/26/2007 3:50 AM
Re: Paper Washer
10/26/2007 4:06 AM
Thanks for you kindly response,but I can not get the thickness on the site.I want 0.76mm thickness washer.
Re: Paper Washer
10/26/2007 4:58 AM
What tolerance do you have on the 0.76mm? If you can use 0.75mm, then you could try here:
http://www.jameswalker.biz/jwco/categories/compressed_fibre_jointings.html
They have 0.75mm in the 'Sentinel' brand.
Drew
Good Answers: 120
Re: Paper Washer
10/26/2007 10:31 AM
Is this just a spacer of high density fiber for shipping purposes?. It must not stick to the parts?
Why muct it be .76 mm, it can be almost any thickness.
Seems to me you should be able to find such fiber in chines. It can be a non woven synthetic felted stuff, like tyvek.
Per Ardua Ad Astra
Re: Paper Washer
10/26/2007 4:21 PM
You should be able to get it in china , why exactly 0.76mm , even 0.75 or 0.8 should do , these are too miniscular considering machineries your showing
Re: Paper Washer
10/26/2007 8:18 PM
are you needing to maintain the gap for hole alignment after reassembly?
Have the sheetmetal shop punch out a jig for you.
Man I'm tired.
Re: Paper Washer
10/26/2007 10:10 PM
It sounds like wealdcn017 is using paper as a consumable shim while machining, to displace the gap where a rubber seal will go. Seems like there should be a better way.
Brad
Re: Paper Washer
10/28/2007 10:50 AM
Right,because the rubber seal is 0.76mm when assembling,so we have to use the same thickness washer to machining the holes.The tollerance is 0.025mm,so we can not use 0.75mm washer.
Re: Paper Washer
10/28/2007 11:19 AM
That's what I figured. As a machinist I suggest taking the time to jig up some device that will allow you to clamp the two pcs together while separated by .076 gage pins or such.
Bend a pair of contours that are the profile of your housing at the split. Say something like a 2in wide aluminum 1/2" thick or so with a series of .076 pins in a straight line hole pattern press-fit in. Now push the 2 housings together and secure against the pins. Perform machining ops.
Even if you are machining one half housing at a time a similar device should be workable.
Hope this helps.
cr3
Good Answers: 120
Re: Paper Washer
10/28/2007 11:36 AM
A rubber seal will deform more than .01 mm when placed into service.
If the tolerance is .025 MM, then .75MM shim is within that tolerance of .725MM to .775MM
In addition, if you are drilling bolt through holes, the tolerance is unimportant and you can bolt the parts directly together, properly aligned, and drill through until done.
Sometimes people include specs that are not important
Per Ardua Ad Astra
Register to Reply 12 comments
ad016 (2); Anonymous Poster (1); aurizon (2); TexasCharley (2); U V (1); vikas (1); wealdcn017 (3)
