Previous in Forum: AMPL   Next in Forum: Thesis for Final Year
13 comments
Can I Customise My Android OS to Send Coded Message Through a Phone Call?
12/25/2019 1:56 AM
Through research I came to know that the mic in our mobile phone takes in frequencies between 300kHz to 3.2MHz and send it during a calling process. So can I reduce that frequency from 3.2 MHz to 3.1 MHz and send a coded message with a frequency of 3.2 MHz and add it along with the voice data and send it by customising an android OS ?
So the data before and after convertion should be like this:
Before : 300kHz to 3.2 MHz of voice signal so bandwidth is 2.9 MHz
After : 300kHz to 3.1 Mhz + a coded signal of 3.2 MHz so bandwidth is 2.9 MHz.
The question is , is this possible ?
Should I make hardware changes for this to happen ?
Pathfinder Tags: Android development
Re: Can I customise my Android OS to send coded message through a phone call?
12/25/2019 8:21 AM
I wish I had a microphone like that! The highest frequency you can pick up with your cell phone mic is about 20KHz.
https://www.researchgate.net/figure/Sensitivity-response-of-mobile-phone-HTC-One-X-using-reference-GRAS-Class-1_fig2_305671983
What actually gets transmitted is less than this. Signal processing in the cell phone extracts the minimum necessary frequency components from the voice spectrum to allow intelligible communication.
12/25/2019 12:21 PM
Thanks for the the reply
I got that data from this Wikipedia Page
I am also not sure about that
12/26/2019 6:07 AM
Nowhere in your reference does it suggest an upper frequency limit higher than 22kHz
12/26/2019 9:14 AM
I am sorry that was not Mhz it was khz
Thanks for pointing out the mistake.
12/25/2019 3:18 PM
12/26/2019 9:18 AM
No , i am not looking for that
I am looking for technologies like DTMF.
12/26/2019 2:36 PM
DTMF technology consists of tones within the audible range. If you press keypad keys during a conversation the recipient will very likely hear them, and you could use add-on hardware to decode them. The phone itself will register and display the numbers, but hacking into that would be a major programming exercise.
https://en.wikipedia.org/wiki/Dual-tone_multi-frequency_signaling
Re: Can I Customise My Android OS to Send Coded Message Through a Phone Call?
12/25/2019 8:07 PM
You don't need to modify anything to send a code. "The sky is blue" could be a code for "meet me in St. Louis".
For encryption, you might need to modify the phone.
12/25/2019 8:21 PM
I'm going to take a guess at what you are trying to accomplish: You want to send a coded message through the audio of a phone call...
Maybe this or something similar is what you are looking for...
https://play.google.com/store/apps/details?id=bit.zeyde.audiomodem&hl=en_US
12/26/2019 9:12 AM
Yes , exactly
I was looking for this type of apps.
Now i need to know whether is this possible through a phone call at a particular frequency through its transmitting link without making any hardware changes.
12/26/2019 10:18 AM
I think it should work. The best way to find out is to try it. It's a free app.
Making any hardware change to a phone is nigh impossible, IMO.
12/26/2019 10:25 AM
I should be able to do it.
But will I be able to reduce the frequency of the input from mic.
12/26/2019 11:38 AM
I would suggest you contact the developer and explain what you're trying to do.
https://github.com/romanz/amodem/issues
Register to Reply 13 comments
Carl_E (1); Jerinsam (5); phph001 (2); Rixter (4); SolarEagle (1)
