Previous in Forum: controllers   Next in Forum: High-Temperature Differential Pressure Switch
Engineering Fields - Instrumentation Engineering - Global Technical Village Engineering Fields - Control Engineering - Control Automation Engineering Fields - Biomedical Engineering - Engineering Philianthrophy Engineering Fields - Electromechanical Engineering - Electromechanical Tacho Engineering Fields - Engineering Physics - Physics change you life Engineering Fields - Energy Engineering - Save earth Engineering Fields - Environmental Engineering - Human Recycle Engineering Fields - Mechanical Engineering - We move earth Engineering Fields - Nanoengineering - Minute study Engineering Fields - Systems Engineering - Systems in Place
For digital display output what should be the input
10/25/2007 9:33 AM
For a Digital display input given is 4 -20mA @ 230VAC. Then for the dispaly is only this 4 - 20mA sufficient for functioning or do we need to give a seperate DC power( 24V DC).
One who is afraid to ask is ashamed to learn
Re: For digital display output what should be the input
10/25/2007 9:58 AM
Some diplays are loop-powered devices, using the 4-20mA only. Some need a separate power supply. The original equipment manufacturer's manual will explain this in detail.
From the description above and without being able to see the instrument it appears that the manual needs to be read more closely. Connecting 230VAC onto 4-20mA input terminals may result in and a subsequent need to replace the instument.
Beka (among other suppliers) produce digital displays, most of which are loop-powered and do not use a separate supply.
10/26/2007 1:06 AM
Thanks for the clarification
10/25/2007 9:34 PM
2 wire 4-20ma interface can offer power by itself converter inner.
3wire can be powered by host.
depend on whichone you will select.
read description details
Good Answers: 54
10/26/2007 1:49 AM
There are displays that can operate with only the 4-20mA signal and there are displays that require a separate power supply. You'll have to determine that yourself.
If the display that you have has just two terminals, it's a good bet that the instrument is loop powered (gets its power from the 4-20mA). If it has four or more, it may need a separate power supply. Note the "may" in the last sentence since the other terminals might not be power terminals.
It might be easier if you could post a picture or give the brand and model of your display. Else, a more detailed description would be enough.
Register to Reply 4 comments
cnpower (1); Jaya Krishna (1); PWSlack (1); Vulcan (1)
