Previous in Forum: Enhanced Reality Contact Lens   Next in Forum: Headhunting
High Resolution Image of Sun from New Telescope
01/30/2020 9:33 PM
"The National Science Foundation's Daniel K. Inouye Solar Telescope has released its first images. They reveal unprecedented detail of the sun's surface and preview the world-class products to come from this preeminent 4-meter solar telescope."
"The Daniel K. Inouye Solar Telescope has produced the highest resolution image of the sun's surface ever taken. In this picture, taken at 789 nanometers (nm), we can see features as small as 30km (18 miles) in size for the first time ever. The image shows a pattern of turbulent, 'boiling' gas that covers the entire sun. The cell-like structures -- each about the size of Texas -- are the signature of violent motions that transport heat from the inside of the sun to its surface. Hot solar material (plasma) rises in the bright centers of 'cells,' cools off and then sinks below the surface in dark lanes in a process known as convection. In these dark lanes we can also see the tiny, bright markers of magnetic fields. Never before seen to this clarity, these bright specks are thought to channel energy up into the outer layers of the solar atmosphere called the corona. These bright spots may be at the core of why the solar corona is more than a million degrees."
https://www.sciencedaily.com/releases/2020/01/200129131449.htm
Re: High Resolution Image of Sun from new telescope
01/31/2020 12:28 AM
Looks like a big bag of Cracker Jacks....
...all shmooshed together...
Re: High Resolution Image of Sun from New Telescope
02/01/2020 7:35 AM
Looks like a plate of sweetcorn!
02/01/2020 7:42 AM
These responses are sooo corny.
02/01/2020 8:12 PM
An interesting engineering problem is that this telescope, when pointed at the sun, is a 13-foot diameter burning glass. You have the problem of disposing of 13 kilowatts of heat.
02/03/2020 9:38 AM
That looks tame compared to shots taken from farther away.
Thank you NASA.
Bazzer Englander (1); JE in Chicago (1); Rixter (1); SolarEagle (1); wrenchtwirler (1)
