Previous in Forum: Pressure Vessels Support Design   Next in Forum: Frequent Jamming of Wall Deslagger-9
23 comments
Engineering Fields - Manufacturing Engineering - Hobbies - Musician - Engineering Fields - Mechanical Engineering - Popular Science - Weaponology -
Good Answers: 39
Grinding & Finishing Stainless Steel Sheet Metal Welds
01/31/2020 11:27 AM
I have two stainless steel sheet welding issues I'd like your feedback on.
  • Grinding/finishing outer corner welds of 304 stainless steel sheet (as in fabricating a cabinet), to match the #4 grained finish of the rest of the cabinet.
  • Dealing with (or preventing?) the heat discoloration on the outside of the cabinet, when brackets are welded to the inside surfaces of the cabinet.
As to the first issue... my new employer currently scuffs or grinds the entirety of our SS cabinets in order to match the resulting finish created by grinding down the outer corner welds. I made the suggestion that perhaps we should try to make the welded area match the #4 finish of the entire cabinet, rather than making the entire surface match the welded area. I'm talking about roughly, washing machine-sized cabinets. So... a whole lot of scuffing with flap wheels, hand held pads, etc. All I need is to match the grain of #4. May I have your suggestions on some processes you believe would achieve this... saving us massive amounts of time with Scotch-Brite pads?
The second issue is somewhat related. We weld brackets to the inside of this sheet metal. It's 11 GA 304SS. We get a lot of discoloration from the heat on the outside... the opposite side from the weld. Is this avoidable? Is our welder doing anything wrong, or something he could improve to minimize these brown and purple oxidation? Once again, this is removed with flap wheels and other abrasives that don't quite match the over all #4 grain, and once again being reason to scuff up the entire cabinet surface, to be uniform. Suggestions?
I've not seen these issues to the same extent, in other sheet metal fab shops I've been in. I've certainly not seen anyone need to scuff several dozen square feet of perfectly acceptable surface in order to match welded and grinded corner welds. I know there must be a better way.
Thanx!
Re: Grinding & Finishing Stainless Steel Sheet Metal Welds
01/31/2020 12:06 PM
You can use a rubber backed straight edge and a finishing block holding a scotchbright type scrubbing/finishing pad. These greenscrubby like pads come in different grits
The discoloration on the backside can be reduced/eliminated using shielding gas on the backside or a heat sink. Less heat input will tend to be less of a problem.
Good Answers: 39
01/31/2020 12:46 PM
Ah... using a straight edge... good idea!
01/31/2020 11:12 PM
Since the shop is in the habit of refinishing the entire outer surface at the end, moving to just minimal refinishing might require more significant changes than merely just handling the corners and heat discoloration individually.
What is shop hygiene like, especially with respect to grinding (and other) dust? Is the protective film left intact to the greatest degree possible on the stainless sheets while fabricating? How are workpieces moved/positioned during fabrication? How prominent in the mind of welders/fabricators/ finishers/anyone handing the product, is the protection of the stainless finish?
There are likely significant benefits to be gained by limiting refinishing to the minimum, but it could take a lot more than just the right scotchbright pad and straight edge reference.
If a shop is in the habit of being able to throw a piece around because the whole thing will get refinished at the end, there may be a significant slow down (and maybe some pushback) as processes are updated to avoid finish damage during fabrication.
There might be capital expenditures required such as more effective dust collection systems and fixtures for positioning workpieces during fabrication. Material costs might even increase slightly by a requirement for more robust protective film on the stainless sheet. The reduction in man hours could mean these are small investments for a big payoff.
Good Answers: 39
02/01/2020 9:50 AM
Thank you. All of what you say is relevant. The protective film issue is the very first thing I addressed, as there was no film at all. In my past experience film was left intact even to the point of delivery of the completed product to the customer, except for minimal removal where necessary for welding.
These parts are delivered to us pre-cut from a vendor; Alro, in fact. Alro uses a laser table to cut the shapes, and then we fold them on a break and weld it together at the corner seams, then add the internal brackets. The reasoning of no film was that it was difficult to remove melted film after welding. This, of course, is simply a matter of judicious removal in the right areas. So I'm working on that aspect.
As far as pushback, that won't occur. They are more than eager to find a solution and modify their processes however is needed. But their focus up to this point was directed toward finding the best way to scuff the entirety of the cabinet surface, to match the grind and finishing of the corner welds. This is where I came in, and it's where we're at, at the moment.
So again, thanks. I'll take all this into consideration.
Good Answers: 146
01/31/2020 2:59 PM
" The No. 4 Brushed finish can vary with different suppliers and even from batch to batch from the same supplier. The variations arise from differing manufacturing conditions, such as wearing of the abrasive belts used in these finishes. Some level of variation should be expected when ordering No. 4 Brushed finish. "
"The finish is created by sanding the stainless steel in one direction with a 120-180 grit belt, followed by softening with a 80-120 grit medium non-woven belt."
https://www.metalsupermarkets.com/stainless-steel-finishing-options/
You may have to experiment with different grit belts, to find a best match to your finish. If the brushed area stands out from the original, reverse the direction of your work with the belt.
incus opella
Good Answers: 39
02/01/2020 9:52 AM
Thanks artsmith.
Good Answers: 92
01/31/2020 11:15 PM
Backgassing will help minimize the discolouration.
If you can make up some forms out of sheetmetal that can be held in some way over the outside of the weld, that cover at least 1" past any weld points and connect them to shielding gas- plain nitrogen will work if the backsides don't get too hot- flowing about 1/2 what the gun setting is. The point is to exclude oxygen from the backsides of the weld to prevent crystallization. A change of hue is very hard to avoid, but this should eliminate browning.
The other option is to hit it with pickling gel. Since this is normally nitric acid based, to restore the chromium oxide layer, and often also contains hydrofluoric acid it's not something I recommend to anyone not well versed in the hazards of these materials.
Good Answers: 39
02/01/2020 10:24 AM
Thank you JNB. The nitrogen method might be a bit too technical to accomplish with our limited welding setup. But I will look into the acid paste you mentioned. In fact I do believe they've begun to look into this themselves. I'll follow their progress on this.
The discoloration issue will probably be the easier of the two issues I mentioned in my original question, to solve. I just wanted to put the question out there to make sure I got all possible options from this experienced pool of professionals on CR4.
As I mentioned in my response to another comment on here, the protective film issue is another thing I've got to address. They've been taking it off. Included in their reasoning is the fact that the internal brackets that I mentioned are located near the center of the sheets after it's folded. So removing it only in the areas that wilk see the heat of the weld is difficult. Its two long L-shaped welds on opposite sides of the inside of the cabinet.
So I see that I've got some options on discoloration resultant from the bracket welding. Now I've got to address the fact that they are scuffing the entire cabinet's #4 surface to match the corner weld grinds and finishing, instead of the other way around.
Good Answers: 92
02/01/2020 12:15 PM
Back gassing is REALLY easy to do. All you need is a spare bottle, regulator and hose and some way to contain the gas.
When I'm welding pipe, all I do is tape over the far end, poke a pencil through the tape so there is somewhere for the gas to flow, and seal the near end with anything from tape to aluminum foil or clay, depending on how close it is to the heat. For flat surfaces I've used the corner cut off of a cardboard box, this will work quite well if you want to try it on a couple of welds to see the difference. You don't want a lot of volume in there.
If it does make a difference there are lots of ways to fit it in production, including having recessed areas in welding tables so the guys can just position the part over it, hit a valve and start welding.
One thing about protective film- I find it's often harder to take off after welding nearby! Sometimes it shrivels a bit, sometimes it seems to cook on.
Best of luck.
Good Answers: 34
02/01/2020 6:45 AM
It usually happens that yellowing discoloration occurs welding SS. Heat Input was not controlled. Clean the affected areas (Water and Soap) and then passivate it. Pickling is a good idea.
Good Answers: 39
02/01/2020 10:31 AM
Thank you Whitephone. I'll add this to my options.
Good Answers: 92
02/01/2020 12:35 PM
Also- if there does seem to be any question of whether or not you should keep refinishing the cabinet exteriors, you may want to consider starting with mill finish material instead.
It costs less, and it is probably not much more work to apply the finish afterwards versus what you're doing now.
02/01/2020 7:26 PM
Here is a link to an electronic weld cleaner that will remove weld tint.
http://www.screenpro.net/weld.html
02/02/2020 10:25 AM
Note to above link:
This is an electrolytic process,and removes the oxidation and discoloration only,it does not affect the before-weld finish.
If you have lots of SS to finish,this is the way to go.
02/02/2020 3:52 AM
Maybe for the welded edges, you might mask the majority of the surface and only have the grind come to make a 1" frame around the #4 grain of the original metal.
This eliminates the need to resurface the whole piece and provides an easy and controllable outcome.
Interior welding needs passivation unless you want disgruntled customers. I've seen cabinets locally rust where the internal welds have not been passivated, even when the delivered product was visually OK when received. We had the supplier come back and rectify them at our multiple sites.
Good Answers: 39
02/19/2020 10:36 AM
Yep. This is pretty much what I ended up doing. Thanx for the suggestion. It's really the simplest and most obvious solution.
Good Answers: 25
02/02/2020 11:36 AM
There is a lot of good advice here. One thing I didn't see was using copper or aluminum "chill bars" on the back side of the weld to help control discoloration.
Troy
Good Answers: 42
02/03/2020 1:20 AM
The following does not address your blending problem, but may help.
In a previous job I had, we partially eliminated the problem by forming the cabinet differently. Edges where formed so that the welds occurred in the inside, out of sight. (You could actually bolt the sections if you wanted). With the majority of the outside being a formed edge dressing was greatly minimized. We still ended up with short welds at the corners where the walls met the ceiling/floor, but the long vertical / horizontal welds were concealed. This was a great cosmetic improvement for bench board tops, and gave a very uniform rounded edge that was controlled in the brake press.
Good Answers: 39
02/19/2020 10:32 AM
This is a good suggestion, and I will be exploring it in the future. Can't bolt, as this is a pressure vessel... well, actually a vacuum vessel. But I've formed cabinets like you suggest, in the past. Although I did bolt them together inside. Maybe I can keep all welds on flanges, on the inside.
02/03/2020 7:23 AM
I always blast the area with glass bead after the weld. it will take off the oxidation and leave a matt finish. Afterwards you can then match your surface finish which may be less work since you are merely just applying your surface finish.
02/03/2020 11:41 AM
Once I weld tubing, all I do is tape over the far end, poke a pencil through the tape so that the gas can flow anywhere, and cover the near end with anything from tape to aluminum foil or clay, depending on how close it is to the heat.
Good Answers: 39
02/19/2020 9:58 AM
Thanks to all for the suggestions. I've made considerable improvements to the process in the last few weeks.
Most importantly, I've discovered that we were actually using a 2B Mill finish to start with. Then the entire cabinet was "buffed" to achieve something similar to a #4. Actually, they've been trying #4 in the past, but were removing the film, and/or ordering it without film at times. All over the map, really.
So, I've immediately changed our material to #4 with a protective film. And of course, it now stays on; all the way to delivery of finished product. Instant improvement in many ways.
Also, we now have an electrochemical weld cleaning machine. It's quite amazing. Virtually erases discoloration just by passing the wand over it; just like an eraser. The pads on the end of the wand are an expensive consumable, as one machine uses up about a dozen of them, but the net gain by using this process is already considerable, in numerous ways.
As far as the grinding of the outside welds... just some shaping, buffing and light scuffing to match the adjacent #4 with a bit of film pulled back. It's working just fine.
These seem like obvious fixes. And frankly, they are. I appreciate you pointing them out and giving me options. I was hired by a company that used to be a purely sales company. But they decided to become manufacturers of this product so they could make their own to sell. They know very little about manufacturing, and have hired me to turn them into a viable manufacturer of this product line. Small family owned business. The opportunities for improvements are nearly endless, as I apply 30+ years of contract/consultant engineering experience to their new facility here. It's quite fun! For once, I have a willing management and a willing workforce desiring changes and improvements. No one will be getting their panties in a twist and grumbling about "the way they've always done it".
Great gig!
Thanx again.
10/12/2020 2:37 PM
You can tape it off and do it, it’ll puts a clean edge on it.
and if that’s not good enough, I take was is appalled a black wheel, and blend it...
it’s a polishing wheel, Stiff yet resilient. I don’t recall the name for it,... I’ll have to look in my notes... but your local abrasives supplier would now.
Register to Reply 23 comments
artsmith (1); GW (1); HiTekRedNek (2); JNB (3); Just an Engineer (1); Out of Box Experience (8); phoenix911 (1); setlock77 (1); Troy36 (1); truth is not a compromise (2); Whitephone (1); williamhakespeare123321 (1)
