Previous in Forum: The Gradual Demise of the CR4 Instrumentation Forum   Next in Forum: Actuator Display Showing Torque Trip CL Alarm and Torque Trip OP Alarm
Earthing
02/20/2020 2:00 AM
Hi mates
When I try to measure the volts(24 V DC or 230 AC ) ,by putting the leads ,the black in earthing bar and the the red in the +ve DC or L in AC ,the PLC and all other system is hanged communication lost
what the main cause of this
Re: Earthing
02/20/2020 7:25 AM
Check your meter connections.
It may be in AMP measurement setting,which is a very low resistance shunt across the line.
This will effectively short circuit the output of the circuit,and if sufficient power is available from the source,it will blow the internal fuse in the meter,or the measured circuit.
Re: Earthing
02/20/2020 4:05 PM
GA, my first thought as well.
Re: Earthing
02/23/2020 9:15 PM
It would be interesting to hear what the OT'er has to say about it? Anything better to offer??
Re: Earthing
09/13/2020 7:40 AM
It is very easy to leave the meter in the wrong setting,especially if in a hurry.
I was using my fluke to record Min/Max on a ultrasonic flow meter,and left it turned on during the night,testing for intermittent problems.
It was the dog days of summer,and the weather was very hot and humid,and of course,that was when my home A/C unit quit.
I hurriedly retrieved my meter from the shop and checked for voltage at the compressor,"Boom" the lights went out in the whole house.
At first I was puzzled,then I looked at my meter,the leads were still in the amp setting....Dang it!
Even after more than 30 years of troubleshooting,I had made this stupid mistake.
The meter was not destroyed,it had blown the 10 amp KTK fuse and survived with no internal damage.
Gotta love those Fluke Meters!..it had tripped the 100 amp main and did not even spark at the meter leads.
The meter was rated for explosive atmospheres,and it did it's job very well indeed.
Anyway,it was a bad compressor,and I had to replace it,pull down the system,purge with nitrogen, install a new filter and recharge with Freon..it was #22 back then.
Haste makes waste,as the saying goes.
Re: Earthing
03/13/2020 4:37 PM
The problem seems to be that a competent test Technician is conspicuously absent.
Re: Earthing
03/29/2020 11:53 AM
Where I am from, the L or line on AC is the hot lead. We put our meter ground lead on neutral.
Are you using AC powered measuring equipment? Many more situational details would be needed for a meaningful solution.
Anonymous Poster #2
Re: Earthing
09/12/2020 10:59 PM
Hi,
1. check the integrity of the meter?
2. are you trying to measure on the PLC IO output?
Rgds,
Anonymous Poster (1); Brave Sir Robin (2); Haymaker (1); HiTekRedNek (2); PWSlack (1)
