Previous in Forum: horse trailer electic brakes   Next in Forum: What constructs a flame?
On demand hydraulic pumps?
10/27/2007 7:08 PM
I'm wondering about taking out a two stage pump and installing a single stage with a flow rate of 30gpm and it's a continuous running pump or an on demand pump is it possible to run two things at one time.and is there a diagram that i can get to show how the on demand theory works?
thanks in advance.
syl
Re: On demand hydraulic pumps?
10/29/2007 5:34 AM
'On demand': switch it on when it's needed; switch it off when it isn't.
30gpm. OK. What discharge pressure?
10/29/2007 9:15 AM
You may be looking for a load sense pump. For information on LS pump you may want to try:
http://www.hydraulicsupermarket.com/
For a pump and a few schematics:
http://www.eatonhydraulics.com/products/pdfs/E-PUPI-TM002-E.pdf
Good luck.
10/29/2007 9:46 AM
Sounds like a closed centre hydraulic system with a variable displacement pump that runs all the time, but only pumps out fluid when there is a demand. The demand triggers the variable displacement mechanism (usuallyu a swashplate or the like) that puts the pump "into stroke" and causes it to pump. This is pretty standard in the industry and any one of the major hydraulic suppliers: Rexroth, Vickers, Eaton, etc. can help there.
Never underestimate the power of stupid people in large groups.
Good Answers: 266
10/29/2007 1:56 PM
Replacing the two stage for a single stage may not work with out replacing the motor. The two stage pump will have dual gpm ratings one for each stage of the pump.
At high pressure the motor may not be able to handle the load.
Good Answers: 114
06/16/2011 10:57 AM
<luke>
Garthh (1); JDknut (1); ozzb (1); PWSlack (1); SlideRule (1)
You might be interested in: Stage Lamps, Vacuum Greases and Vacuum Pump Oils
