Previous in Forum: Harmonics In An Electrical Circuit   Next in Forum: DC Motor Field
8 comments
Voltage Regulator Chips
10/30/2007 4:43 AM
A warm hi to all!
I have query regarding regulator ICs available in the market.Say for e.g 7805 (1A).
If 7805 regulator is supplied with +12 at its input terminal in one case and in another case If it suppied with +24 v at its i/p terminal , then does this i/p voltage makes any diffrence in heating of the IC? (In both cases, assume the same load.)
Re: Voltage regulator chips
10/30/2007 6:07 AM
is i/p meaning current and power?
if you connet 24v at input, the power certainly changs. no problem.
the current depends on lyou r load. if load constant, the current dont change.
i= v/r
as your voltage increase, the power dissipate increase. your chip iwll be hotter than front.
10/30/2007 6:20 AM
I mean to say:
If 7805 is used to provide regulated +5v to one ciruit, with +12v at its input terminal in one case and with +24v at its input terminal in another case with the same ciruit(i.e. load does not get changed but only input voltage to the 7805 get doubled.)
As fas as i think as per your comment 7805 will dissipate more heat with +24 v at its input terinal than +12 v input.
Is it right?
10/30/2007 7:59 AM
As other said the power dissipation goes up with the input voltage. The power dissipation of t he 7805 is (Vin - Vout) * Iout. The efficiency of the power conversion is Pout / Pin or Vin / Vout is a very close approximation for linear regulation. If you can afford the power dissipation and want to keep the 7805 cool you can pre-regulate with an LM137, a zener in series or just a properley sized resistor in series. Either way you will probably need a heat sink. If you want to save some power and their is a few extra bucks in the budget try a switching regulator.
Re: Voltage Regulator Chips
10/30/2007 11:22 AM
Well , your warm Hi to all is quite apropriate.
Using your example , the 7805 is a 3-pin +5V 1A voltage reulator.
To calculate the power dissipated in the regulator , you subtract the output voltage ( 5V in tis case ) from the supply voltage ( say 12 V) and multiply by the load current.
The load current wil vary somewhat, but lets assume full load of 1A.
then the power dissipated is (12-5)X 1 = 7 Watts.
If the supply vlotage was 24v then the power dissipated would have been 19 Watts.
Your heatsink wil have to be sized to dissipate the heat from the regulator.
10/31/2007 12:41 AM
Hai everybody....
Actually the 7805 Regulator is a +5V regulator. When it is fed with +12V it will regulate the o/p voltage to +5V consuming some current internally... When the 7805 is connected to +24V input the o/p anyway will be regulated to +5V but the current taken internally to regulate is more than compared with the +12V input..
The load current depends upon the load. The total current is the summation of the Load current & the device internal consumption current.
Thanks & Plz. reply I am wrong.....
10/31/2007 1:30 AM
Thank you very much Everyone here to contribute your valued experience.
My concept gets cleared regarding regulator chip.
Good Answers: 12
11/04/2007 9:33 PM
Does anyone know what the maximum input voltage is for the 7805?? I don't have a book handy, but I would check that parameter before running it from 24 volts.
Bill
11/05/2007 2:46 AM
Yup!
definately i knew it!
Max. i/p to 7805 is 35v
Register to Reply 8 comments
Anonymous Poster (2); cnpower (1); fireball (3); PLM NY (1); Sciesis2 (1)
