Previous in Forum: Voltage Regulator Chips   Next in Forum: Grounding of star neutral
DC Motor Field
10/30/2007 7:07 AM
Front bearing of my ,125 Kw DC Motor heat up what could be the possible problem,
Bearing sizes are up to the skf standrad ,and the bearings are NU 316 and 6315.
Re: DC Motor Field
10/30/2007 7:50 AM
What does the local representative for the motor manufacturer say?
Good Answers: 61
Re: DC Motor Field
10/30/2007 10:16 AM
The possibilities are endless. I have found the most common problem on the front (shaft end) bearing to be misalignment between the motor and the load. Other options:
  • Lack of lubrication
  • Vibration due to improper mounting of the motor or load
  • Vibration due to cavitation (if the load is a pump)
  • Vibration in a hollow pedestal mount
  • Bent motor shaft
  • Bearing outer race rotating in the housing.
I would first disconnect the motor from the load and run the motor unloaded for several hours to see if the problem returns. If it does not, the problem is likely in the load or the alignment between the motor and load.
Re: DC Motor Field
10/31/2007 6:17 AM
thank u 4 reply
The motor is off the machine (with out Load, in the workshop) and its DE side bearing
(NU 316 )heat up while the motor was running off load, after overhauling ,both bearing were replaced with the new same No.
Re: DC Motor Field
10/30/2007 11:25 AM
When you say "front baring" I assume you mean the inboard or the one nearest to the load coupling.
You may want to check the alignment on the coupling.
The front bearinmg my be heavily loaded from a misalignment hence the overheating.
Re: DC Motor Field
10/31/2007 6:21 AM
i mean DE side and the motor was off the machine ( with out coupled to Load )
Re: DC Motor Field
10/31/2007 7:28 AM
The new De end Bearing is heating up on no load after replacement. How long was the motor run ?Normally initial heating can also be due to Over greasing .If the bearing was in store for a long time it could have lost its property.U need to clean it up and Grease it up.Normally any new bearing heat up and becomes steady after running it in.So if everything was ok including fixing the new bearing try runnning it for a few hours and temp would start dropping.
Belgium - Member - New Member
Good Answers: 21
Re: DC Motor Field
10/31/2007 11:09 AM
Are you sure that it is the bearing that is heating up? In most cases there is an "Zimmerring" sort of oil seal placed before the bearing. This seal when new, gives friction on the driving end shaft?. Possible this will be the heating source. How hot runs your shaft? temperatures up to 60 / 70 degrees Celcius are common.
Anonymous Poster (3); nesubra (1); pwr2thepeople (1); PWSlack (1); rudy.leurs (1)
