Previous in Forum: Fiber Optic Communication in Space   Next in Forum: "Brain Scanning" Lie Detectors
Designing Data Aquisition System
01/30/2006 8:46 AM
I've had a new Drain field installed at my facility. It contains electric actuated valves. These contain two microswitches each. 1= normaly open, 1= normaly closed. I want to transmit via wireless signal, real time data from the valves to my PC in my office For monitoring purposes only. I would like room for expansion to add more misc switches to monitor other operating systems in my plant. Where do I start? -- Every day above ground is a good day.
Data monitoring.
01/30/2006 8:52 AM
Hi. Go to a web site called www.shockwatch.com They make real time wireless process monitors which may be able to be used for your application. Regards, Simon Hancock.
Re:Data monitoring.
01/30/2006 9:01 AM
North East Tech. Sale, has a battery operated wireless system. We use it and it works for us. Call and find out if it will work for you. The phone number is 215-513-1000.
Good Answers: 18
Wireless data transmission
01/30/2006 9:23 AM
Are the valves underground? Can you monitor the current in the microswitches?
Re:Wireless data transmission
01/30/2006 9:50 AM
Yes, and yes. I've already provided wire leads into a junction box above ground where I have 120volt power available.
Good Answers: 18
01/30/2006 11:14 AM
As a simple start to monitoring the state of the switches, look at http://www.omega.com/toc_asp/subsectionSC.asp?subs ection=K&book=das&all=1 which is Omega Engineering's variety of wireless data transmitters and receivers. Hope this helps. If not, then, can you be a little more specific about how you would like to get your data?
Omron has Bluetooth Wireless for your application
01/31/2006 7:48 AM
Omron has Bluetooth wireless you can build a panel with wireless communication and have expansion capabilities with the right PLC. The part number is PROMI-SD202-0A.
Contact Monitoring
01/31/2006 8:35 AM
Note that if microswitches are used for monitoring make sure they have gold plated contacts (or are what is called self wiping). The current flow in typical IC circuits used for monitoring for an open/short condition is tiny, not sufficient to burn off any organic buildup that can occur on contact points, eventually giving a false open.
Register to Reply 7 comments
Anonymous Poster (2); Bill (2); Howetwo (1); RBP (1); strawberrymccoy (1)
You might be interested in: Gas Valves, Industrial Valves, Solenoid Valves
