Previous in Forum: Running Architectural Desktop 2007 with Vista   Next in Forum: Why Do We Fold a Paper Before We Cut It?
Submarine Propulsion System
10/31/2007 10:39 AM
I am interested in the article about the submarine that used the Kerk Motion products for extending the shaft from motor to propeller. I need a system for 250psi. Can anyone give information on the product I should consider from Kirk products in relation to the recent Submarine contest.
Thanks for replies.
Good Answers: 54
Re: Submarine Propulsion System
10/31/2007 10:11 PM
I think it's best that you contact them directly.
http://www.kerkmotion.com
I'm not sure what you mean by "extending the shaft from motor to propeller". I doesn't seem to need anything special if all you want it so connect the motor to the prop.
If I misunderstood what you said, please say so.
11/16/2007 12:28 PM
Thanks for reply; I have designed a small submarine and completing the propulsion system. Most of what I'm doing I'm designing myself but can not come up with the proper seal for a rotating shaft. I want my vessel to exceed 250psi of water depth which is about 300 feet of water. I have some camera housing from Iklite that is rated for 200 feet with external camera controls. I am looking at the rubber washers to see what they have done. In a propulsion shaft I know I need a bearing system for the shaft to rest on and other water tight washers.
Canada - Member - New Member
Good Answers: 11
11/16/2007 1:55 PM
What is your shaft diameter?
Good Answers: 54
11/17/2007 5:10 AM
Ah! You're referring to a shaft seal or stuffing box, I believe. I'm afraid that this is beyond my expertise but I've found a reference in Wiki:
http://en.wikipedia.org/wiki/Stuffing_box
I only learned about these things while watching Junkyard Wars a few years ago.
You might find some useful info if you google "stuffing box" +submarines or "shaft seals" +submarines. Good luck.
11/01/2007 8:54 AM
And adding to Vulcan's question,
What do you mean by "system for 250PSI?"
Wangito
Never trade luck for skill.
gigaconcept.com (1); trongod (1); Vulcan (2); wangito (1)
