Previous in Forum: Voltage Between Earth and Neutral 220V   Next in Forum: Rotor Current
Bosch L4816 Battery Charger
06/07/2020 2:19 PM
I am in need of the schematic diagram for Bosch L4816 Battery Charger,
Pathfinder Tags: battery charger
Re: Bosch L4816 battery Charger
06/07/2020 2:49 PM
Probably located on one of the interior panels of the charger, or possibly the owner's manual...
Here is a typical 12v battery charger circuit diagram....many others to choose from...
06/08/2020 1:54 AM
Is there some reason why this cannot be obtained by contacting <...Bosch...> using the telephone?
06/08/2020 2:37 AM
Also, there is a discussion on this very topic running at the moment on the Quora website.
06/08/2020 5:13 AM
Is this a 48V 16A battery charger for some form of battery powered equipment like a sweeper, pedestrian stacker, golf cart or similar?
If it is an automatic charger then you may find that for the unit to work it needs to sense a battery on the output.
I just repaired a 36V 25A auto charger for a golf cart and the sense circuit needs to see a battery voltage of about 70% by some brochure ware though I did find it switched on at a much lower terminal voltage around 50%.
Hare today, goon tomorrow!
Register to Reply 4 comments
PWSlack (2); SolarEagle (1); Stef (1)
