Previous in Forum: productivity   Next in Forum: TESTING OF CRANES
14 comments
steam trap
11/04/2007 1:33 AM
What is a steam trap? What are the functions of a steam trap?
work is fine if it doesn't take much of your time.
Pathfinder Tags: steam trap
Re: steam trap
11/04/2007 2:40 AM
In steam lines some of the steam condenses into water, this can then cause what is known as water hammer, the sudden collapse of steam into condensate, to prevent this they fit a steam trap, a little float that lets the water out but traps the steam inside. This is mostly associated with heating steam line or auxiliaries.
Regards JD.
Good Answers: 19
Re: steam trap
11/04/2007 7:07 AM
When I in your age starting new with a job and undrgoing a trainning session on
The instructor showed us the following Poseters:
1. A horse pulling a cart - Horse Trap.
2 . A Mouse caught in a trap - Mouse Trap
3 . A Bird in a cage - Bird Trap
4 . A naked woman - Man Trap
5 . A TD Trap - Steam Trap
So like the naked woman whos function is to trap man , a Steam Trap is an equipment whose job is to trap steam. Clear !
Steam is gas and will condense to water giving off its latent heat . That water (condensate) needs to be taken out else it will stay in the pipeline collecting to cool down incoming steam, occupying space inside pipe so the line starts getting filled/water logged and creating water hammering (pipe vibration). The steam trap then takes out the water/ condensate and as soon as condensate is drained out and the steam comes it shuts (traps).
Sajid, where are you located ? Pakistan/India let me know. If Pakistan which city - I'll teach you, If India/USA/Canada - I'll tell you where to go.
Re: steam trap
11/04/2007 8:38 AM
Here are a couple spots to visit in your adventure and educational endevours.
http://www.engineeringtoolbox.com/steam-traps-d_282.html
Here is a breakdown on the operations and fail modes of steam traps.
Here is an animated view of a mechanical trap.
Animated view of a thermostatic trap.
Basic information with links.
Good luck with the school....... 8>) Maximo
Re: steam trap
11/04/2007 8:45 AM
thanks for providing good links on the topic.
sajid ahmad
Re: steam trap
11/04/2007 8:40 AM
good.
so steam trap is basically used to drain the condensed steam.
can you tell the locations on a steam pipeline, where the steam trap should be fitted ?
Good Answers: 19
Re: steam trap
11/04/2007 12:55 PM
his Lordship has detailed you everything. You now need to study. You are now expecting us to do your homework.
Good Answers: 50
Re: steam trap
11/05/2007 12:32 AM
Why don't you stop trying to suck the brains out of CR 4, and hire yourself an engineer!
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
Re: steam trap
11/05/2007 10:06 AM
must . . . not . . . be . . . sarcastic!
-A-
question everything
Good Answers: 19
Re: steam trap
11/05/2007 4:23 PM
Del hasn't come in yet. He'll rip him apart.
See my reply on top. I offered him to teach him but he did not reply.
He knows his answers yet is acting dumb!!!!!and trying out our patience.
Re: steam trap
11/05/2007 9:48 PM
very nice examples.
Re: steam trap
11/05/2007 5:26 AM
Re: steam trap
11/05/2007 3:31 PM
spirax-sarco has perhaps the best design guides for steam trap design. I always refer to their design guide book when designing new systems. If you have a local rep in your area call him up and see if he can bring you a copy of their hook-ups book.
If not, there is always the web:
http://www.spiraxsarco.com/applications/examples.asp
Good Answers: 19
Re: steam trap
11/05/2007 4:11 PM
He is from India and his local Rep. is Forbes Marshall who manufacturers:
1 . Spirax Sarco products.
2 . Bacharach (Fyrite) products.
3 . Coachran Boilers.
4 . Cambridge instruments.
5 . Electro Medical Instruments.
Is situated in Poona/India with Offices in all major cities in India.
He just wants us to do his leg work and not worth it.
Re: steam trap
11/08/2007 10:59 PM
Many steam traps are actually T&P steam traps for temperature and pressure. You'll definitely need them on any steam system that returns its condensate back to a condensate PUMP. It allows the condensed WATER to pass through but does NOT allow the steam to pass.
The T&P trap prevents the steam pressure from pushing back the return line and causing trouble for the condensate pump.
If you have a small steam system and the condensate return line rises up to a spill-over tee in the equalizer line, no condensate pump or T&P traps are required.
check this link for everything you ever wanted to know about steam traps
http://www.spiraxsarco.com/resources/steam-engineering-tutorials/steam-traps-and-steam-trapping/mechanical-steam-traps.asp#head8
Unless you're the lead dog on the sled, the view is always the same....
Register to Reply 14 comments
-A- (1); Anonymous Poster (1); ducon (4); healybj8 (1); jdretired (1); LordMaximo (1); sajid ahmad (2); Sniccus (1); vasu (1); vermin (1)
