Previous in Forum: Strange Parts Inside a Dryer in a Mining Plant   Next in Forum: Milling Machine
Milling Machine
08/20/2020 1:10 AM
horizontal milling machine is suitable for arbor mounted cutting operations (plain , side, straddle, gand) operations. but vertical milling is easy for end milling and face milling since end mill and face mill cutters are directly attached to the spindle by an adapter or chuck. by definition, vertical milling machine do not allow arbor mounted cutter. so does it mean face milling on vertical milling machine and plain milling on horizontal milling machine the same thing??suppose i have only horizontal milling machine.
Pathfinder Tags: milling opreations
Good Answers: 225
Re: Milling Machine
08/22/2020 12:39 AM
My milling machine has both vertical and horizontal capabilities with separate drive systems for each.
The same face face mill arbors, drill chuck, collet chuck, etc that I use in the vertical drive also fit in the horizontal drive as they employ the same spigot, and I sometimes have need to use those arbors in the horizontal drive for specific tasks, although horizontal face milling with these cutters is somewhat limited by the presence of the vise.
By judicious use of ganged cutters etc, you can achieve an entirely satisfactory face finish using just the horizontal capability, and in some circumstances can be faster than the vertical face cutters, but vertical is generally mush easier, especially on my mill where, to use the horizontal feature, I need to rotate the entire upper portion of the mill 180° to bring the outer support for the horizontal arbor into play.
Obviously, if you only have a horizontal mill, slot cutting etc. becomes a tad more difficult, and you can find that you require a vastly more complex set of cutters to achieve the same results as you could with a vertical mill with a lot less hardware.
Re: Milling Machine
08/24/2020 5:55 AM
Surely there must be a User Manual that came with it?
Why would anyone buy such a thing without having some understanding as to how it works?
Register to Reply 2 comments
