I'm planning to use 9 Numbers of Light fittings with 250W Metal Halide lamps in a area of 30m X 20m to be used as a fuel filling station. The building structure has 8 Numbers of columns(6m in height) supporting the Roofing with a flat ceiling. (No walls, ensure free air flow in all sides) The light fittings are to be surface mounted.
My worry is whether the heat generated by this light fitting will have any contribution towards increasing the ambient temperature at the working level. What are the additional safety aspects that I should consider in this regad...
Can I look for some expert advice from this forum?
Thanks!
