Previous in Forum: Metal Halide Lamps   Next in Forum: Earthing 101
Why Does Clearance Between Phases Increase with Altitude?
11/07/2007 2:42 AM
Why clearance between phases increases with altitude ?
Re: clearance between phases
11/07/2007 2:58 AM
The flash-over distance (i.e. the distance a spark can jump for a given voltage difference between two conductors) increases as air pressure decreases.
Without looking it up, I suspect this is due to the increase in mean free path of the ions as the pressure decreases. (Mean free path is the average distance a particle can travel before colliding with another particle).
Re: Why Does Clearance Between Phases Increase with Altitude?
11/08/2007 8:37 AM
The first sentence by JohnDG answers the question completely.
There are more variables in "Relative Air Density".
Dan
"I believe we are masters of our lives - we hold all the cards and it is up to us to use them right." Vesna Vulova - survived 33,000ft fall
11/14/2007 9:22 PM
After 60 years in the business, I did not know it did.
Voltage, capacitance and corona considerations and are the main criteria in the US.
Where does your information come from ?
Of course the higher voltages are on higher poles.
Snakers
11/15/2007 12:30 AM
Physics degree from many years ago.
11/15/2007 4:41 PM
Sorry if I was a bit short there - I was doing a quick check on CR4 before dashing out to scrape the frost off the car & make an early meeting for a service call-out.
If my memory still works, this is the sort of reasoning behind having low pressure gasses in discharge tubes. Too many gas molecules in there, and the ions can't get a decent run at it.
I still haven't looked anything up, and it's a long time time since I needed to know about such things. No doubt someone will put me right if I'm out of it.
John.
11/21/2007 7:44 AM
Check out www.corona-technology-course.com for more info and resources.
Register to Reply 6 comments
CoronaCameraMan (2); JohnDG (3); Snakers (1)
