Previous in Forum: Water Detection at Pump Intake   Next in Forum: Loose-tube vs Tight-buffered Fiber Optic Cable
Telecom Engineer
09/16/2020 7:26 AM
I need a devise installed on telecom tower to give to TMC indication that the deflection of tower increased the allowable value 0.5 degree or the tower may be dropped off If someone experienced such case please refer to me
Re: Telecom Engineer
09/16/2020 8:30 AM
A simple google search gave me this in about 1 minute:
https://www.shockwatch.com.au/product-category/impact-tilt/tilt-indicators/
Knowing where to find information is almost as good as knowing it.
09/16/2020 9:06 AM
What you know is limited, what you can learn is not...so better
09/16/2020 8:32 AM
I think you need an instrumentation engineer and not a telecom engineer. (Yes, many telecom engineers can also act as instrumentation engineers but it is a different discipline.) I would use a MEMS inclinometer sensor module, like this company's product, combined with a simple single board computer or microprocessor to insert the tilt data into the available telecom stream. A PLC system may also be able to handle this communication.
I expect you will have to low pass filter your results to remove momentary trips. It will probably also be a good idea to have a structural engineer at least look at the tower to say if a half degree tilt should be considered normal or not.
09/16/2020 9:52 AM
High accuracy measurement of deflections of an electricity transmission line tower
https://www.sciencedirect.com/science/article/abs/pii/S0141029614005434
09/16/2020 12:19 PM
If it were not a homebrew tower then a call to the tower's original manufacturers would be a good place to start, always assuming that the tower is sufficiently functional to be able to handle the call.
09/17/2020 10:40 AM
If you are referring to the actual positioning of the tower, I would think hanging plumb bob on a wire would allow you to check for movement in the tower.
Or have a survey crew check its plumbness twice a year and after sesmic and severe wind events.
If you are refering something truly telecom, I am sorry I wasted your time.
09/17/2020 10:53 AM
There are several listed on a well-known internet auction site (name withheld) right now, starting from £0.99GBP.
Register to Reply 7 comments
ccoop609 (1); HiTekRedNek (1); PWSlack (2); redfred (1); SolarEagle (2)
