Previous in Forum: Driveway in Colorado Strong Enough to Support Garbage Truck   Next in Forum: Water Treatment Cost
Check Valve Direction at Bypass Line of Pump
10/02/2020 4:12 AM
Dear all
I noticed that on some of drawings; the check valve direction at bypass line of pump set is flowback. But some of the drawing showing as, the check valve direction at bypass line of pump set is toward as pump output direction.
which one is correct? if both are correct, let me know the purpose of these different design.
Best regards
NT
Re: check valve direction at bypass line of pump
10/02/2020 5:20 AM
The version on the right is the more usual.
I can imagine a scenario for which the left version might work, but I've never seen it.
I have some questions about the right version also, which may take some discussion. It is late here, so I'll defer until after noon.
10/02/2020 6:28 AM
Thank you Tornado
once time, I have seen one page at internet. this page showed as:
check valve forward direction for use to the water when no pump running time (electrical outage).
check valve backward direction for the overflow water more than require flowrate to flow back to the source.
i want to confirm to my knowledge about this issue, so i have re-seek out this page at on internet. But, i haven't see this page again at internet. So i have suspected that this page is showing to wrong information and no longer posting at now. So i ask and discuss with CR4.
Best regards
NT
10/03/2020 8:42 PM
I agree, forward might be to bypass stopped pump.
Another possibility for reverse bypass might be pressure regulator...
https://www.equilibar.com/application/pressure-bypass-valves/
Re: Check Valve Direction at Bypass Line of Pump
10/02/2020 9:22 AM
10/02/2020 9:58 AM
It depends upon the circumstances.
it is not unknown for a booster pump to be installed in parallel with a forward-facing check valve so that the check valve closes when the pump turns on.
it is not unknown for a check valve to be reverse-facing in parallel with a pump so that a minimum flow is maintained through it while it is running.
If in doubt, discuss the matter with a local Process Engineer.
10/05/2020 7:45 AM
Have seen and worked with "forward bypass" for in-line pumps between reservoirs. When receiving reservoir was lower than source, flow happened under gravity. when replenishment of receiving reservoir was insufficient, then the pumps engaged and provided higher flow. Typically pumps only ran a few hours per month instead of twice daily as was the case before bypass.
Bypass valve however also had stop valve upstream and downstream to enable removal and service while the line still serviced the reservoirs.
Just an Engineer (1); nt (1); PWSlack (1); Rixter (1); SolarEagle (1); Tornado (1)
