Previous in Forum: Generating Quality Leads These Days?   Next in Forum: Someone Help Me Explain My Delusions When it is Sunny?
26 comments
Dilute an Acid
11/05/2020 12:14 PM
I have a liter of distilled water PH7 and I have 31.45% Muriatic Acid, Question how much muriatic acid do I add to achieve a 5% acid solution. Metric or imperial , metric is prefered.
Re: Dilute an Acid
11/05/2020 1:53 PM
I think this is how to solve it...
n = number of liters of acid solution contains 0.3145n pure acid and 0.6855n water
Amount of pure acid = 0.3145*n added
Amount of water added = 0.6855*n added
Pure acid / pure water = (0.3145*n)/(.6855*n +1) = .05
0.3145*n = .05*(0.6855*n + 1)
(0.3145 - 0.05 * 0.6855)*n = 0.05
n=0.05 / (0.3145 - 0.05 * 0.6855) = 0.178428 liters
Re: Dilute an Acid
11/05/2020 2:36 PM
31.45% / 5% = 6.29 parts water to 1 part solution...
Re: Dilute an Acid
11/05/2020 3:44 PM
314.5ml acid * 20 = 6,290ml water - 685.5 water in solution = 5604.5ml additional water to solution
Re: Dilute an Acid
11/05/2020 5:09 PM
skip to 9:48 for sample problems if you like...
https://www.technologynetworks.com/neuroscience/tools/molaritycalculator
Re: Dilute an Acid
11/05/2020 5:27 PM
Re: Dilute an Acid
11/06/2020 12:30 AM
There is a couple of ways to approach the problem. The first is to add to the 1000 ml of water and the second is to pour off some of the 1000 ml and add the 31.45% solution.
First to add solution to 1000 ml
1000 = ml H2O
x = ml HCL solution
.3145 = concentration of X sol
.05 = concentration of new sol
.3145X/(1000+X)=.05
X=189 ml
Checking:189*.3145=59.44 g HCL
59.44 ml HCL /1189 ml final solution * 100 = 5%
Second to remove solution:
for a .05 solution of 1000 ml = 50g HCL
.3145X=50
X=159 ml of 31.45% solution
Therefore pour out 159 ml of the 1000 ml water and add 159 ml of 31.45% solution.
Re: Dilute an Acid
11/06/2020 1:24 AM
It depends on whether the <...5%...> is by volume, by weight, or by molar quantity, which has been withheld from the forum.
Re: Dilute an Acid
11/06/2020 10:07 AM
Thank You PW, that was what I was looking for. Makes a difference.
Good Answers: 137
Re: Dilute an Acid
11/06/2020 10:44 AM
Yes, but chemicals are supplied as % w/w, as I said in #11. Eg caustic soda 46% w/w NaOH, sulphuric acid 96% w/w H2SO4. Perhaps the OP will come back and comment.
Re: Dilute an Acid
11/06/2020 12:26 PM
In my world we have several ways to "measure" depending on what you are trying to achieve in the final result. God knows I wish it were simple percentage.
Re: Dilute an Acid
11/06/2020 3:17 PM
Does it make a difference? He said the solution he was using was 31.45% HCL.
The problem then becomes a simple dilution/concentration calculation. The one posing the question knows whether it's by weight/volume/molar concentration. So calculating as a straight forward volume to volume would seem to be perfectly valid because in the end we should arrive at the same result. You can reframe the problem as "How much water do we add to a volume of 31.45% HCL to reduce it to 5%." The result will be in whatever units the original solution was made from.
Good Answers: 137
Re: Dilute an Acid
11/06/2020 4:39 PM
That's right, but almost certainly 31.45% HCl is % w/w
Re: Dilute an Acid
11/06/2020 7:35 PM
I stand corrected. After reflecting on my previous statement I returned to my original approach and used 34.15 g-HCL/100 g-sol and recalculated using the 189 g of the 34.15% solution and discovered, much to my chagrin, I had a 5.4% solution by weight and not a 5%. Thanks for pointing it out; so I guess I'll just limp on out and retire from the discussion...
Good Answers: 137
Re: Dilute an Acid
11/07/2020 6:10 AM
No problem! Glad we've sorted it
Re: Dilute an Acid
11/06/2020 3:20 AM
1 mole muriatic acid solid = 24.19 ml = 36.46 grams = Molar volume: 24.194 cm³/mol
https://www.aqua-calc.com/calculate/mole-to-volume-and-weight/substance/muriatic-blank-acid-coma-and-blank-solid
Re: Dilute an Acid
11/06/2020 3:49 AM
<...achieve...>
To one significant digit, like the <...5%...>, or to four, like the <...31.45%...>?
Good Answers: 153
Re: Dilute an Acid
11/06/2020 6:39 AM
100cc of 31.45% acid contains 31.45cc of concentrated acid and 68.55 cc of water.
To dilute to 5% it needs 19x the amount of water to acid ie. 597.55 cc to 31.45cc acid.
So you have to add 597.55-68.55 = 529cc to the original 100cc to make 560.45cc diluted to 5%
Good Answers: 137
Re: Dilute an Acid
11/06/2020 9:01 AM
It's usually called hydrochloric acid, HCl nowadays, but each to his own!
Assuming the 31.45% and 5% are % w/w, as is usual in the chemical industry.
1 litre water has mass 1000 gm. If x gm as HCl are added to 1 litre, x/(1000+x/31.45%) = 5%. That gives x = 59.45 gm as HCl, 59.45/31.45% = 189 gm acid as supplied. Not 189 ml, as Rich said in #6.
As you're more likely to measure it by volume, density of 31.45% acid = 1.16 gm/ml, so needs 189/1.16 = 163 ml.
Re: Dilute an Acid
11/06/2020 9:56 AM
Out of interest, what is this <...5% acid solution...> going to be used for, please?
Re: Dilute an Acid
11/06/2020 2:33 PM
It will be used to activate another solution for an end product. Details not permitted at this time.
Re: Dilute an Acid
11/06/2020 2:13 PM
~ 4 shots...
Re: Dilute an Acid
11/06/2020 2:18 PM
I'll drink to that!
Re: Dilute an Acid
11/06/2020 2:57 PM
Thanks every one and all. I got my answer and it was probably closer than what I was doing. It appears to me any way a tad more involved than I realized.
Re: Dilute an Acid
11/07/2020 2:00 AM
It was implicit in some answers but to state it explicitly: dilute acid into the water rather than water into the acid.
I used to call on the chemical compounding industry and plenty of workers have been hurt by not remembering this. Another common error is adding water to concentrated caustic.
Re: Dilute an Acid
11/07/2020 9:25 AM
Are you trying to obtain a certain Ph level?
If so, the best way might be to titrate the mixture using a Ph meter or precision Ph test paper.
Add 1 ml. each step, and stir and measure after each addition once you get close to the target value.
Your distilled water may not respond linearly.
Re: Dilute an Acid
11/09/2020 7:01 AM
This is why I love my Galaxy Note
So add 189 grams of the acid.
Register to Reply 26 comments
Codemaster (4); HiTekRedNek (1); jhhassociates (1); Kevin Johnson (1); PWSlack (3); R_i_c_h (3); Randall (1); rashavarek (3); Rixter (1); roy hammy (2); SolarEagle (6)
