Previous in Forum: Dilute an Acid   Next in Forum: Steam Volume
Someone Help Me Explain My Delusions When it is Sunny?
11/24/2020 3:50 AM
Hello Tom, I look forward to receiving my interest in this question. Curiously, every time I go out on the street on a sunny day, I often see a puddle in the distance, but until I get closer, nothing. I want to know what phenomenon it is, and why there is such a phenomenon, looking forward to receiving a genuine answer, thanks.
Re: Someone help me explain my delusions when it is sunny?
11/24/2020 4:11 AM
Re: Someone Help Me Explain My Delusions When it is Sunny?
11/24/2020 5:04 AM
This would not be characterized as a delusion, but rather an optical illusion, in other words you are not imagining it, it is a real thing...
Tip: ...mute sound...
5
11/24/2020 5:44 AM
As both replies so far have said it's a mirage.
Basically because the sun is shining on the road, the road heats up, and, a layer of air hotter than the air above forms just above the road. Light travelling close to horizontal is then totally internally refracted by the change from cooler air to hotter air. Total internal refraction looks just like a reflection which is the way you normally recognise a puddle.
11/25/2020 3:49 AM
As others have said it is a mirage caused by the thermal inversion between the hot and cooler air near ground level however if it is a Mirage then you are in deep doodoo as it is flying close to the ground or you have wandered onto an air strip where the first mirage forms because of the large expanse of heater tarmac.
Hare today, goon tomorrow!
11/29/2020 9:55 PM
I wouldn't call it a delusion or an illusion. What you see is real. You are seeing light that is being modulated by a media density change due to heated air. A shimmer.
11/30/2020 3:36 AM
"Reality is an illusion brought on by a lack of alcohol." - Anon
Register to Reply 6 comments
Anonymous Poster (1); Haymaker (1); PWSlack (1); Randall (1); SolarEagle (1); Stef (1)
