Previous in Forum: slow speed Induction motor   Next in Forum: HOW TO REDUCE THE NOICE LEVEL OF A GENERATOR?
LED Driver problem
11/12/2007 12:09 AM
hi, i want to create an LED bar indicator that runs off an output that varies from 0 - 1500mV, is there an IC anyone can recommend for this, or can i modify and existing system like the ones using these IC's LM3915 or LM3914?
https://datasheet.octopart.com/LM3914N-National-Semiconductor-datasheet-7282609.pdf
CR4 Admin: fixed broken link
Re: LED Driver problem
11/12/2007 3:49 AM
Yup... that LM 3914 looks like the one I've used before. NS usually have V good app' notes.
Good Answers: 18
11/13/2007 8:43 AM
LED's need about 1500mV minimum before they emit light. Are you asking whether or not you can modify the LM 3914 circuit to make it work from zero to 1500mV with no higher voltage available? The LM3914 is actually a bunch of comparators and a voltage divider. The LED's are virtually driven digitally from a higher source voltage, and the external resistor deterrmines how much current flows through the LED's, which inherently controls brightness.
Hook up an LED to a variable power supply, and slowly raise the voltage from zero until you just begin to see light. Don't raise it much higher, or you'll destroy it. You must reach that threshold voltage before the LED becomes forward biased and starts emitting light. I think you'll get a good handle on what I'm talking about.
