Hi, I have small problem. I cannot find functionality young module E on temperature ( I need from 20degC to 350 degC ) for material aluminum alloy 2618A. I will satisfied with similar chemistry material.
I forgot to mention that the 350°C is a very high temperature for al-alloys. Usually over 200-250°C there are creep problems. For temperature so high the value I gave is i think too low and variable strongly from the temperature value.
Thank you very much.It looks great. This is material for pistons. I need solve it by FEA but measuring on piston shows above first ring temperature more than 320degC. FEA results give temperature in center of piston temperature around 350degC. Could you say me where I can find more info about this mat. creep properties ? I will be very happy :-))
