Previous in Forum: Young Module For 2618A   Next in Forum: Research a Taper FOS
Spectral responses
11/13/2007 10:55 AM
Does anyone have detailed spectral responses of various plastics? I am looking to maximize transmission for LWIR.
Re: Spectral responses
11/13/2007 1:54 PM
I don't have detailed information, but on the anti tank missiles that use the thermal image of the jet to direct the missile to target, the lens material is a germanium arsenic construction, if I remember correctly.
This was for long wavelength infrared transmission.
John.
11/16/2007 4:57 PM
Low OH silica (quartz), or sapphire, would also be good alternatives to plastic. They would also be more durable. Certainly be less expensize that GeA crystal.
The website for the Rochester Cluster has a listing for a company that makes plastic lenses. That would be a good start if you need to stay withe plastic to keep things on the cheap.
Register to Reply 2 comments
You might be interested in: Spectral Lamps, Spectral Filters, Spectrometers
