Previous in Forum: Keeping track of time...used by my computers   Next in Forum: Tact Time Calculation Software
14 comments
Math Software
11/13/2007 5:57 PM
Where can one obtain/purchase a software ( not too complicated ) that can take an equation ( as an input ) and graph it on , say cartesian coordinates graph paper or on a log-log graph paper ? For example, I input the equation for a sine wave and it plots it to scale; or the equation of four different sine waves as an input and it plots the sum total .
Good Answers: 66
Re: Math Software
11/13/2007 6:08 PM
With a little work, Excel will do it, or are you looking for something else?
Aequam memento rebus in arduis servare mentem.
Re: Math Software
11/13/2007 7:05 PM
Hi Reno Nevada : OK , how do you use excel to create curves , such as fuse and breaker trip curves, and different combinations of sine curves to illustrate harmonics in a particular circuit ? from Ottawa, where the morning walk to work is at 28F.
Good Answers: 66
Re: Math Software
11/13/2007 7:23 PM
It does take some work, but it's possible.
If you know your function, plug it into a series of cells to create your data set for whatever range you require. You may need to play with your intervals a bit to get things looking like you want. Then simply use your data set to plot your chart. You can use the fit curve function to smooth things out. You can lay as many data sets on a single chart as you can read.
Follow?
Don't feel too bad, morning temp at my place was only 31F today.
Re: Math Software
11/13/2007 8:58 PM
Thanks Guy ( I mean CSM ) !.
Good Answers: 66
Re: Math Software
11/13/2007 10:42 PM
Anytime. If you run into problems, just IM me. Good luck!
Good Answers: 109
Re: Math Software
11/15/2007 3:27 AM
Hi,
I do similar and much more complicated calculations with mathcad.
They have a free 30day trial version.
I estimate you will solve your problem within 1 hour after reading the "getting started" section.
I recently did bending and buckling of flexure hinges, errors and particles in ballbearings, elastic structures in bycicles, airbearing design and more.
RHABE
Engineering Fields - Mechanical Engineering - Member Engineering Fields - Piping Design Engineering - Member United Kingdom - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
Re: Math Software
11/15/2007 4:31 AM
I was just about to say that exact same thing.
I use Mathcad on a daily basis, and after a slowish start from using it through the Open Uni I now find it a very useful bit of software.
Like RHABE says - you can get a free 30 day trial of Mathcad 14 for being a member on this forum. Check your E-mails over the past few days.
Kev B
Re: Math Software
11/15/2007 9:38 AM
I also have been using MathCAD, since it was a DOS program. Unfortunately, it is no longer available in an affordable version. When i bought my last update, I could get MathCAD for about $100 or the pro version for about $1200 (IIRC). Now, you can only get the pro version.
Steep learning curve, but pretty short. One hour should get you going, another hour should have your graph.
Re: Math Software
11/15/2007 10:12 AM
Thanks # 6,#7 and #8 : But at $1200 , that's a little steep for me ( by $1000. ).
Re: Math Software
11/15/2007 10:53 AM
I too had MathCAD 3.5 for DOS and upgraded it to 4.0 for a nominal fee and I was able to afford it while a grad student. This was before academic discounts etc. The funny (sad?) thing is that for most of my work with MathCAD, I really don't use the capabilities much beyond the DOS version. It would be nice to pay for the version that suit ones needs instead of getting a Ferrari to run to the store to buy groceries.
Re: Math Software
11/15/2007 12:12 PM
Unfortunately, PTC isn't interested on anything low-cost. Look a Pro-E compared to other 30d modeling programs.
Apparently, the low-cost version was dropped about the same time PTC took over.
Re: Math Software
11/15/2007 7:19 PM
I think mathcad can do the magic.
Good Answers: 213
Re: Math Software
11/15/2007 8:55 PM
Try SciLab. Free. Pretty much like MathCad...
Re: Math Software
11/16/2007 5:38 AM
I teach math and often need to get a quick graph up on the lcd or printed. There are any number of free applets on the web. I use mthagv obtainable at www.mathgv.com. Very nice down and dirty app.
Register to Reply 14 comments
Anonymous Poster (1); Brave Sir Robin (1); brojoe (1); CSM Engineer (3); cwarner7_11 (1); HarryBurt (2); Kev_brown (1); ovide brudo (3); RHABE (1)
