Previous in Forum: Pressure Measurement   Next in Forum: Paper Sensor
9 comments
Ultrasonic Water Bath
11/13/2007 10:42 PM
I want to know about the electronic circuit and working principle of ultrasonic water bath used in pharmaceutical industry . If some information about the sourcing of the circuits & Transducers ,prefabricated tanks etc. it would be great .
Re: Ultrasonic water bath
11/14/2007 12:59 AM
Its widly used in industry for cleaner,
the main parts are ut transducer and driver. I woder how much power do you hopt to get?
you can paste the tranducer at the bottom of basin, then use hf power drive it shock.
you can make it us an ordinary audio power amplifier.( no transformer as output media)
Re: Ultrasonic Water Bath
11/14/2007 11:54 PM
It's a specialality subject. Power requirents depends on tub, water quantity and objects in the tub. One most importent thing is tuning the out put og the electronic generator to the tub with and with out load. Any small change in the tub phycal properties will fail the tuning.
11/15/2007 12:16 AM
Dear Guest ,
Your answers sounds good !
Can you elobrate the process of tunning and calculation of power rating w.r.t the tank & transducers with some example .
regards
aks
11/15/2007 6:49 AM
Very interesting. We clean metal surgical instruments in our L&R dual frequency ultrasonic. It does perform very differently ay times. Yours may be the answer. Thanks.
bobguz
"If we all worked on the assumption that what is accepted as true is really true, there would be little hope of advance." -- Orville Wright
11/15/2007 7:06 AM
Technically, the transducer load is really a capacitive load where the transducer becomes part of the output "tank" circuit (not to be confused with the liquid tank). A lot of them are designed to oscillate around the 40 Khz mark, though they can be made to oscillate at any frequency. The frequency is really dependent upon the transducer and associated components and the power would be determined by the handling capacity of the transducer.
Emergency night landings...as you approach the ground, turn on your landing lights. If you like what you see, leave 'em on. If not...turn 'em off.
11/15/2007 8:09 AM
The following link is very informative and explains how imploding air bubbles produsce plazma jets that perform the cleaning action.
http://www.blackstone-ney.com/index.php
11/15/2007 11:48 AM
Is it possible to extend Ultrasonic cleaning baths to human bathing?
What would be the problems?
11/15/2007 12:36 PM
I was a grad student in biochemistry when we used an ultrasonic probe, referred to as the dildo, to liquify dead rats. And my fingers get very uncomfortable very quickly in our small ultrasonic bath.
bobguz
Popular Science - Weaponology - New Member Popular Science - Cosmology - New Member Safety - Hazmat - New Member
12/14/2007 10:41 PM
Look up Ultrasound Cell Homogenizer.. ":<)
Register to Reply 9 comments
aks (1); Anonymous Poster (3); bobguz (2); cnpower (1); Flying boots (1); I)AVI) (1)
