Previous in Forum: Ultrasonic Water Bath   Next in Forum: I@E TECHNICIAN
10 comments
Paper Sensor
11/14/2007 12:46 PM
Hi,
Can anyone suggest a suitable sensor to be used with a photocopier and a remote counter, so each time a sheet of paper lands in the out tray the remote counter counts up by one. The counter accepts NPN, PNP, contact closure, etc.
Cheers
Rob
Suppliers of digital panel meters, signal conditioners, panel printers, large digit displays & scrolling message displays
Re: Paper Sensor
11/14/2007 5:21 PM
If you look at some of the reflective opto-things by e.g. Omron (E3X series) or Keyence (PZ-V series), I think you'll find something to do that. You'd probably need to glue a dummy sheet in the out tray so that you coud reliably catch the 1st sheet and spot the 2nd and subsequent.
Edit:
I think the E3X things only work with fibre optics - Omron certainly do an equivalent 'direct' type. I suggest you give them each a call & ask for tech help - they'll trip over themselves to sort you out.
I'd think you'd be paying ≈ £120.
Re: Paper Sensor
11/14/2007 5:45 PM
This sounds like a lot of money for counting sheets of paper.
Low-tech approach would be a low-torque microswitch with a long wire actuator, or a "cheap'n'cheerful" vane operated photo-interrupter type switch.
Good Answers: 120
Re: Paper Sensor
11/14/2007 10:54 PM
all the copiers I have seen have sheet counters built in
Per Ardua Ad Astra
Re: Paper Sensor
11/15/2007 5:06 AM
Likewise.
Another way would be to count the reams taken from the stock cupboard, and do a material balance based upon the re-ordering information coming from the accounts office. Input = output + accumulation is a pet thing for Chemical Engineers....
Re: Paper Sensor
11/15/2007 4:45 AM
The most common way I have seen used is a UV led and a photo diode mounted at about 60° or so to each other in the same (industry standard) package.
The led is focussed on a reflector (polished metal is more than adequate) that lies under the paper path, the LED & Photo diode are above the paper path (or the reverse!). Each time a piece of paper passes through, the IR light is blocked.
Add some signal conditioning and a transistor/relay and connect to your counter.
If the distances needed to cover are greater, then use a separate IR LED opposite an IR detector transistor, but this time, due to the negative effects of lighting at either 50 or 60 hz, you may need to use a widely different frequency for the led and filter out anything not near to this with a band pass filter......slightly more complicated, but i would not be surprised to hear that there are chips available to do this.
Re: Paper Sensor
11/15/2007 3:35 PM
Most of the copiers do have recordings of no of prints printed , but are internally stored , also they have hardware support for interfacing with PC so you can have records on your computer ,but if you intend to have one by wireless on your counter you can attach a sensor like IR detector or relay switch which closses or disconnects with each sheet comming out encode it and send via infrared signal or radio signal to your device that will decode and display
Re: Paper Sensor
11/15/2007 4:19 PM
Rob,
Can you please fill in a few details, here?
As others have pointed out, most copiers have counters built in - why do you need the external sensor?
John
Re: Paper Sensor
11/15/2007 5:59 PM
Thanks for all your comments, you have given me a nudge in the right direction.
I can't talk about the application specifically, but yes I do know that copiers have an inbuilt counter. However, for this application a remote counter is also required.
Many thanks
Rob
Good Answers: 120
Re: Paper Sensor
11/15/2007 7:30 PM
all the little self serve photocopy shop have a bank of remote counters to tally the count.
someone must make them
Per Ardua Ad Astra
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
Re: Paper Sensor
12/23/2007 3:00 PM
Have you tried a Mini Microswitch?
You can input the signal via the contact close/open to your counter. It's cheap, quick and if it fails, then you haven't invested too much time, money or effort!
Also, check-out this site for important info.
www.automationdirect.com/static/specs/sinksource.pdf
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
Register to Reply 10 comments
Andy Germany (1); aurizon (2); JohnDG (3); PWSlack (1); Rob Grummitt (1); ronald (1); vikas (1)
