Previous in Forum: Depression Observed on Weld   Next in Forum: Free Body Diagram - Vice Grip Plier
22 comments
Where to Buy Collets and Collet Nuts, in Plastic and Metal
02/11/2021 10:07 PM
I have a project to make telescopic locking mechanism with pvc and steel pipes. Do you know any online store, which have various size range collets, collets nuts and pipes or tubes?
Re: Where to buy collets and collet nuts, in plastic and metal
02/11/2021 10:20 PM
You mean like Ebay?
02/11/2021 10:37 PM
No, I mean an online store, which sells these type of products.
02/11/2021 11:08 PM
Then we'll need specifications...
02/12/2021 1:18 AM
02/12/2021 8:06 AM
I mean this type of collet
02/12/2021 8:31 AM
See #5⇓.
02/12/2021 10:01 AM
Another issue is that collet creates the telescopic adjustable length mechanism, but it doesn't prevent the tube from detachment if pulls to its full length.
02/12/2021 10:23 AM
Wonderful.
That's everything, then.
<unsubscribes>
02/12/2021 3:31 PM
It seems to me that you have not performed a diligent search on your own,and that you had rather have someone else do the leg work,and present the answer to you on a golden platter. Would you like some wine with that,Sir?
02/12/2021 3:39 PM
I tried my best to search, but I live in Canada, ON & most suppliers are in USA, so either results doesn't show up due to the location or most suppliers don't ship to Canada.
02/15/2021 2:51 AM
<...most suppliers don't ship to Canada...>
Well, deal with those that do, then!
Next!
02/12/2021 6:55 PM
02/12/2021 7:11 PM
02/13/2021 12:37 PM
Thanks for the link.
02/13/2021 12:40 PM
Their MOQ is 1000 pcs.
02/15/2021 2:52 AM
So?
There was nothing about that in the original post.
02/12/2021 8:37 PM
Thanks. This one also available at aliexpress.com. Their shipping time is more than 4 weeks, sometimes more than two months. If couldn't find it locally, then it'll be the last option.
02/13/2021 12:36 PM
02/12/2021 4:24 AM
Mr. Bing certainly does:
Matthew, 7:7.
Re: Where to Buy Collets and Collet Nuts, in Plastic and Metal
02/12/2021 9:51 AM
You could try a woodworking supplier. The cutting bits for shapers and routers are held in place with a collet and collet nut. Various sizes of adapter sleeves, collets, and collet nuts are available. Collet chucks are also used in lathe work - search machine shop suppliers.
02/13/2021 7:38 AM
In a pinch I have used a plastic compression fitting and just drilled the shoulder for the tubing seat out of the bore so the tube will pass through. When using a metal compression fitting, if the same fitting is available in nylon, I use a nylon ferrule in place of the metal one.
If you just need one or two fittings, that might be an option with the parts available at the local hardware or auto parts store.
My aspect ratio is 2.28.
Good Answers: 94
02/17/2021 11:48 AM
Or maybe a cable gland?
Register to Reply 22 comments
canadianslidewinder (1); dkali1 (8); HiTekRedNek (1); jhammond (1); Nigh (1); PWSlack (5); SolarEagle (5)
