Previous in Forum: Facebook password cracking   Next in Forum: Memory Stick
Good Answers: 97
How to translate Pascal to Delphi
11/18/2007 10:47 PM
In pascal I am using a Hercules card (along with the VGA) to track communication with an galil card. The data transfers are written to the Hercules.
It works fine but now I want to change over to 32 bit Delphi.
How do I change the address declaration of the var SKREEN ?
UNIT HERCUTIL;
INTERFACE
TYPE SPO = RECORD C:CHAR; A:BYTE; END;
SPR = ARRAY [1..80] OF SPO;
SPX = ARRAY [1..25] OF SPR;
VAR SKREEN : ARRAY[1..25,1..80] OF SPO ABSOLUTE $B000:$0000;
ROWS : SPX ABSOLUTE $B000:$0000;
procedure hclear (r,r1:byte);
PROCEDURE HDISP (ROW,COL,LONG : BYTE; S:STRING);
PROCEDURE HWRITELN (D:STRING);
PROCEDURE HSCROLLSKREEN;
PROCEDURE HSCROLLUP (R,R1:BYTE);
procedure hdsp (s:string);
procedure hwrite (d:string);
procedure htrace (d:string);
Popular Science - Cosmology - New Member United States - Member - New Member
Re: How to translate Pascal to Delphi
11/21/2007 6:42 PM
Hi Hendrick,
Its been quite a few years since I played with Pascal in a college course elective.
Can't be much help to you I'm afraid.
-John
All worthwhile programmers know that constants always vary.
Good Answers: 97
11/22/2007 3:26 PM
Hi John
The advantage of being a DEY fanatic (Do Everything Yourself) is that you get exactly the functionality you need from the software. The disadvantage is that once the program is running you don't upgrade or keep aware of newer developments.
When you get a new machine you suddenly realize that you became a dinosaur.
I bought a 1080 page book on Delphi maybe I can solve my impossible dream.
I am almost convinced that DOS and pre dos is better than Windows.
11/22/2007 4:13 PM
Hi Hendrick,
Like you, I'm definitely a DEY! A few years ago, I wrote a program (in C) to manage my personal shop; inventory, billing, profit & loss, etc. At the time OS2 libraries were popular and like others around the lab where I worked I incorporated many OS2 functions in my code.
Everything worked fine for several years and I would fix an occasional bug or glitch but no major problems. However! I got careless and failed to back up my hard drive. Wouldn't you know it, that's when my HD crashed! (I had copied the OS2 libraries, include files, etc. on to the HD then lost or misplaced the floppies).
Anyway, I had backup copies of my source code but couldn't compile it without the OS2 libs. Couldn't even find them on the web. So I just started over and rewrote everything in C++.
"I am almost convinced that DOS and pre dos is better than Windows."
In my lab I worked with and supported Unix. The saying around our shop was "Real programmers don't use menus" (refering to Administrator menu functions). Harr Harr! Gimmie that command line prompt and I can do anything. When Windows first came out, many programmers ridiculed it, and rightly so. it was pretty flakey at best.
-John
Register to Reply 3 comments
