Previous in Forum: HVAC Control problem!   Next in Forum: New Firewater Ringmain
Filters For Blower Room
11/19/2007 6:06 AM
We are having blower room with 5 blowers. We are in process of design filters for this room. Total capacity of these blowers are 16000 Nm3/h. What are points to be considered for proper filtered air intake? These blowers air will be used for natural gas fired furnace as combustion air.
Good Answers: 19
Re: Filters For Blower Room
11/20/2007 9:31 AM
Check up Faar Filters' catalogs.
11/22/2007 5:00 AM
Points to be considered may be as under (assuming blowers are handling air)
1 Pressure drop across filter approx < 25mmwc
2 Dust holding capacity of Filtering media
3 Effective area of each Filter frame
4 Filetring media to be water washable (should not shrink while washing by water)
5 Easy access for filter washing
6 Air tight blower room door
7 Roughly one filter frame of 24" x 24" x 6" can take air flow of 1000cfm with
delta P < 25mmwc.You will need at least 10 filters of aforesaid size.You may fix 15 filters.
8 You can fix delta P measurement for arriving at frequency for filter cleaning.
Register to Reply 2 comments
