Previous in Forum: Industrial Projects   Next in Forum: LED Bar Indicator
Cable Size
11/19/2007 6:31 AM
How to calculate a cable size for a particular load?
Good Answers: 18
Re: Cable Size
11/19/2007 9:32 AM
You typically don't calculate cable sizes -- you look them up in a table of standards.
Cable sizes for loads have been determined for copper and aluminum; both common metallic conductors.
Now, for a more in-depth look at it, heat is what determines how much current a conductor can carry, and that depends heavily on the thermodynamics of the application. Copper, for example, has a resistivity (to keep it simple), and I2RCu is the power dissipated by a copper conductor. In free air, the heat dissipated by that copper conductor is a function of air temperature and wind speed, for all practical purposes. When electrical insulation is added to the conductor, thermal insulation is also inherently added. That conductor will not dissipate heat as rapidly to the atmosphere and will become hotter than the uninsulated conductor for the same current. Bundle a bunch of insulated conductors together and stuff them in a conduit, and they will become hotter yet for the same current.
I think you get the picture.
Re: Cable Size
11/20/2007 12:34 AM
You're looking for ampacity charts.
If all else fails, read the directions. That's if, and only if.
Re: Cable Size
11/20/2007 7:12 AM
Emergency night landings...as you approach the ground, turn on your landing lights. If you like what you see, leave 'em on. If not...turn 'em off.
Re: Cable Size
11/20/2007 4:53 PM
Get a book from a cable manufacturer this will give you max A mV/A/m etc from these fiqures you can calculate cable size for load and distance
"Multa ferunt anni venientes commoda secum, Multa recedente adimiunt". (The years as they come bring many agreeable things with them; As they go they take many away).
Re: Cable Size
11/22/2007 3:42 AM
you can find a software solution at
http://www.intelisoft.co.uk/
Bill (1); coconutpete (1); DAHRA (1); Flying boots (1); ktel60 (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
