Previous in Forum: Solenoid Construction   Next in Forum: Electrican
SINGLE PHASE INDUCTION MOTOR
11/19/2007 10:16 PM
I NEED HELP WITH THIS....
When operating at rated load, a 120 VAC 60HZ single phase induction motor can be modeled as a 10.8 ohm resistor in series with a 25.3 millihenry inductor. Under these conditions, what will be the power factor?
Re: SINGLE PHASE INDUCTION MOTOR
11/20/2007 6:56 AM
If it is as you say a 10.8 ohm resistor and a 25.3 millihenry inductor all you need to do is draw a triangle of the impedances and measure the angle to get the power factor.
Simple!
Reply to Forum Thread
