Previous in Forum: Speech Recognition   Next in Forum: 915 MHz zigbee module
Undocumented 8085 Flags And Instructions
11/20/2007 8:14 AM
Its gr8 to say that 8085 has undocumented instructions (10) out of 256 instructions !
check the link to see the undocumented 8085 instructions and flags
UNDOCUMENTED 8085 FLAGS AND INSTRUCTIONS
Does anybody knows actually what the Intel is meaning with the undocumented codes ?
Do they really designed by the designer or are they created by their own during the manufacturing process ?
Why Intel is not releasing the undocumented codes of the mps?
What is the reason for undocumenting them?
Good Answers: 97
Re: Undocumented 8085 Flags And Instructions
11/20/2007 12:23 PM
Undocumented features is quite common. sometimes it is a subroutine used by other functions with a link supplied to them for testing purposes. The problem of using them is that they may disappear on change in the next revision.
Long time ago I bought a XT and I discovered additional functions only to realize that the chip was really intended to be a 186 but was never released and replaced with a 286.
I you can use the functions, go for it.
11/20/2007 12:28 PM
Thanks for the reply !
From where we can get these undocumeted codes ?
why the manufacturers not releasing them along with the instructionset?
Good Answers: 97
11/20/2007 12:38 PM
Sometimes the function had a flaw (example division by zero or range problems) and therefore not safe for them to make available.
I have some 8085 documentation somewhere, have to go through boxes in my storeroom though. If i find them I will post or mail you detail.
11/20/2007 12:45 PM
Thanks again but i already had those undocumented codes of the 8085
specified by the link.
the undocumented codes for higher versions may be helpful but i dont have a collection of them .....
Good Answers: 97
11/20/2007 3:11 PM
I made a 8085 decompiler in ±1983 and had some inside information.
I will not be able to supply the micro code but may be able to supply calling conventions and register status on return.
I think there were more than one version A, B, A2 . . . .
11/21/2007 10:36 AM
gr8 i have also made one too.
its code is written in C and its able to decompile almost all instructions except undocumented ,becoz i was not much aware of the undocumented codes .....
Such informations are really inspiring
Register to Reply 6 comments
