Previous in Forum: Alternate material   Next in Forum: Alkaline battery leakage
Fire Water Pumps
11/21/2007 6:14 AM
Hi
What are the charactaristics for the fire water pumps used for fire fighting?
Can submersible pumps be used as fire pumps?
Thank you
~Atieh~
Pathfinder Tags: fire water pumps
Re: Fire Water Pumps
11/21/2007 9:22 AM
Put simply the requirements are that the pump can generate a high pressure with a high flowrate.
Most pumps are centrifugal pumps I believe. Because of the high power of these pumps they are normally run off a fire tenders engine and so would be difficult to run underwater.
John.
Good Answers: 101
11/21/2007 11:04 PM
Most, if not all, submersible pumps do not possess the extremely high pressure or volumetric flow rate needed for fire fighting, except maybe for very small fires in very confined areas.
Good Answers: 120
11/21/2007 11:21 PM
The input must be kept flooded or the men holding the hose will feel severe pressure pulsing. Since it often requires several men to hold a hose to mush variation like this can be dangerous.
http://www.madehow.com/Volume-4/Fire-Hose.html
http://www.google.ca/search?hl=en&safe=off&sa=X&oi=spell&resnum=1&ct=result&cd=1&q=%22fire+pump%22+%2B%22pressure+variation%22&spell=1
Per Ardua Ad Astra
Good Answers: 50
11/22/2007 11:42 PM
If you are an American Indian, I hereby designate myself as a fire-water pump... Ask what you will!!!
11/26/2007 4:46 AM
In addition to the above, a diesel-driven fire pump will not have a facility to shut it off remotely. In the limit, the engine must drive either to the end of the water source, until it is shut off manually or until destruction, whichever happens first.
Good Answers: 19
11/28/2007 11:47 AM
See NFPA 20
Register to Reply 6 comments
aurizon (1); DVader1000 (1); Electroman (1); PetroPower (1); PWSlack (1); vermin (1)
