Previous in Forum: 100 Amp DB   Next in Forum: How the "ELCB & SOCKET TESTER" Work
10 comments
How to make 110 v bulbs flash
11/23/2007 3:03 PM
I have a stop light and want the bulbs to flash different from each other how can this be done? The unit is 110 volts.
Re: How to make 110 v bulbs flash
11/23/2007 3:32 PM
"I have a stop light and want the bulbs to flash different from each other how can this be done? The unit is 110 volts."
Get some flasher buttons to insert in socket under lamp bulb.
60 Watt Flasher Buttons
Prices have gone up since I last bought some in the last century!
A solid state DIY module would be cheaper and adjustable.
11/25/2007 8:07 AM
Thank you for this is the first time for me at this site.
11/25/2007 9:56 AM
Don't go away - it's good here!
John
Good Answers: 97
11/23/2007 3:43 PM
You could use a PIC and program the flash tempo and duration for quite a few separate flashes. One of the tasks in a PIC course is to have LED's flash at different speeds.
11/23/2007 5:41 PM
Where can I buy some 110V PICs?
11/23/2007 6:03 PM
"Where can I buy some 110V PICs? "
Radio Shack?
11/23/2007 6:35 PM
I searched for "High Voltage PICs", and this is the best I could find ...
http://www.highvoltagepics.com/
Doesn't seem very applicable.
11/25/2007 8:09 AM
Thanks you for this is the first time for this site.
Good Answers: 97
11/25/2007 11:01 AM
Not those Pigs or Pics. PIC the micro controller, you can use it with normal or solid state relays.
My friend is the PIC expert and made me some switches for turning 220v motors on and off controlled by the computer.
11/24/2007 4:42 AM
Timers have On-Delay, Off-Delay and also SOS mode. In SOS mode the output contact can be used for flashing of a bulb and flashing time can be set too.
A thousand-mile journey begins with the first step.
Register to Reply 10 comments
Abbas (1); Hendrik (2); JohnDG (3); Stirling Stan (2); welder (2)
