Previous in Forum: Risk of operation in power plant   Next in Forum: Dariusz
11 comments
rating of induction motor
11/25/2007 9:17 AM
hi friends.....
when i try to calculate ampere rating of induction motor ..it is not calculated by the formula p=1.732*V*I*p.f..... & value of ampere calculated is not matched as written on rating plate.
the motor has given its kw , ampere , p. f. , efficiency...
is there any factor which i need to consider for it ...
plz help
India - Member - Electrical Energy
Re: rating of induction motor
11/25/2007 9:45 AM
Is it Three Phase or Single Phase ?
09/23/2009 11:09 AM
both
11/25/2007 10:37 AM
If I understand, the ampere rating is given on the name plate.
Try these: kW = I x E x 1.73 x PF / 1000 (Must be three phase since you use 1.73)
HP = I x E x 1.73 x Eff x PF / 746 (If you need HP)
The amperage on the name plate is at full load.
Good luck,
James
" adapt, improvise, overcome "
11/25/2007 1:31 PM
Hastings,
Don't you need to use the efficiency for the KW version as well? I had a motor recently that was:
6.3 KV, 257 Amp, 0.85 PF, 0.945 eff, which resulted in a power of
6.3*257.0.85*0.945*1.732= 2252KW.
11/26/2007 2:26 AM
Hi Sandeep,
I think that, you don't need recalculate the ampere rating of induction motor.
Just use the ratted current of Motor manufacturer, and try to use the famous manufacturer e.g. Siemens, Fuji, Mitsubishi, AEG,.....
Best regard.
Nature is unlimited, human's knowledge is limited
11/26/2007 7:44 AM
Actually as per my knowledge at the name plate they given the output power.
so,
i=(p)/(1.732*V*p.f*effi).
If it is true/false for you reply to me
11/26/2007 9:01 PM
Hi ,
Few months ago , i also got the same problem while caluculating the amp rating of induction motor. what i concluded is we must take the factor of efficiency .If u get the correct answer plz let me know at pavan5ee@gmail.com . plz.
have a nice day .
pavan.
11/29/2007 10:12 AM
Hi friends, this is d induction motor rating provided on nameplate= 5 kw , current 9.2 a , v= 400+-10 , eff. 86 percent , p.f =0.92 , rpm=2880. now we use d formula den p = 1.732#400#9.2#0.92. d value of p is not comes to 5 kw. plz prove it.
11/29/2007 10:33 AM
Yes. looks good.
5857 using only PF, 5037 with eff factored.
James
11/30/2007 12:49 AM
OK james, it means i have to consider eff. can u tell me wat r d other equipments in which we need to consider dis eff. like in case d.g sets we didt consider eff. to calculate current. in their rating kva , voltage, current r required eff. is not y it is ? plz clerify
11/30/2007 1:29 AM
Yes It is approximate.
Pmotor=√3*U*I*cosφ(PF)*µ(Eff)=1.732*400*9.2*0.92*0.86=5043W=5.04KW.
Therefore value in nameplate is 5KW.
And can you try again: Siemens motor with 400V three phases, 8.2A, 4KW, Cosφ=0.83, µ=85%, 1440 rpm.
And please don't recalculate something, that were standardized. Three phases Induction Motor is one of them.
Register to Reply 11 comments
Anonymous Poster (2); G.Swaminathan (1); hastingselectric (2); nam70 (2); Repakula (1); sandeep (2); Steve S. (1)
