I am going to design a 11KV switchgear. The switchgear has two incoming lines equipped with VCB's and one bus-coupler. The incoming VCB's will be N.C and the bus-coupler will be N.C in normal operation. In the absence of voltage on any incoming the dead incoming VCB will be switch-off and the bus-coupler VCB Will be switched-on automatically. By voltage restoration the return will be done manually not automatically. There is not any 11kV motor as outgoing feeder, only 11/0.42KV transformers and downstream switchgears exist as outgoing. I have considered an U/V relay for each incoming before VCB and an U/V relay for each half-busbar. My client requested to consider another U/V relay or use of two-step U/V relay on each half-busbar, but I don't know why? Does anyone know more about this matter or a good link? Can anyone help ma about two-step U/V relays?
