Previous in Forum: Humidity   Next in Forum: Automatic Vaccum Testing Pot Needed
magnetic sensor
11/27/2007 7:45 PM
does anyone know of an inexpensive magnetic sensor or system that can scan,detect,or verify the magnetic field in and around a human body and the area in close proximity to said human body?
thanx for any recommendations or advice!
Re: magnetic sensor
11/29/2007 9:20 AM
Good Answers: 109
Re: magnetic sensor
11/29/2007 9:35 AM
Hi, not existing this,
the magnetic dust you collect with your clothings will be likely more magnetic than the magnetic field that is generated from the very small currents inside our body.
Give me 200K$ and I will build you a system.
RHABE
Location: Sunken Meadow (nee Rattle Snake Swamp) L.I., N.Y., U.S.A.
Re: magnetic sensor
11/29/2007 11:11 AM
Absent any magnetic sources nearby, the biggest magnetic field around or inside the human body is the Earth's own magnetic field, which is about 55,000 nanotesla = 55 microtesla = 550 millegauss = about 1/2 gauss. (A Tesla = 1 Weber/meter square = 10,000 Gauss). But the Earth's field is essentially constant. Electric currents flowing in axons and dendrites within the human body produce changing magnetic fields, which can be detected and separated from the steady Earth's magnetic field - akin to separating AC signals from DC signals.
The problem is the very small magnitude of these neuronal currents and their associated magnetic field. Some researchers have used "SQUID" sensors to detect these fields.
http://en.wikipedia.org/wiki/SQUID
Most people break things, engineers fix things.
Re: magnetic sensor
11/30/2007 10:43 AM
fild which you want to measure is very less that can be measured but with inexpensive sensor just impossible. and one more thing when you measure this field it should measure in standard condition. without dust with full antisatic without any magnetic material with body ect ect.
Re: magnetic sensor
11/30/2007 1:34 PM
Something that might help, if not quantitative, al least qualitative. I heard of the Kirlian effect, a kind of halo around a living body, under some high frequency oscillations. Anyway, I have seen the pictures, and they remained in my memory for more than 25 years.
Bridge rule #1: Nobody is as good as he thinks about himself nor as dumb, as his partner thinks...
indel (1); jarunmagnet (1); MechanicOfNY (1); mutantone (1); RHABE (1)
