Previous in Forum: load isolator   Next in Forum: electrical engineering
Control Circuit of Buck Converter ???
11/28/2007 11:32 AM
how can i desing a control circuit to turn on and off the IGBT in buck converter ?
i know i have to do it by PWM but can anyone tell me which IC can i use for it or can anyone give me the full circuit to desing control ciruite of buck converter ??????
thanks
cya
Re: Control Circuit of Buck Converter ???
11/28/2007 2:52 PM
Look at National Semiconductors website...they have loads of good SMPS stuff including the 'simple switcher' series with software that does a lot of the design for you.
A word of warning, this sort of thing is not ideal for amateurs... because of the tricky wound components, and they can easilly go bang!
11/28/2007 11:00 PM
There are lots of IC for you use to the goal, such as
3524, 494 etc very classical IC. hundreds of new IC come to market for selection. such as from Ti,Linear,NT,MT, Irt etc, countless.
But if you hope to design a good control parameter, seems not too easy.
if you like tell me how much math knowledge do yuou hve? I may give you relative suggestion to your knowledge.
voltage loop, current loop and double loop have different method. and trasnformer design. brtw, can you make up a transformer?
11/28/2007 11:07 PM
mean high frequency transformer
11/29/2007 10:28 AM
Have a look at the power control section of texas instruments (ti.com) or linear technologies (linear.com). They have excellent documentations about basics and full circuits as much as you cant read in a month.
Good luck, regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
Register to Reply 4 comments
cnpower (2); user-deleted-1105 (1); uweka (1)
