Previous in Forum: Automation   Next in Forum: Is there a problem with Copyrights?
Hour Meter Reseting
11/30/2007 10:16 AM
How do you prevent an hour meter from resetting during a power failure using a AB slc 5/04? I am using cascading timers/counter.
Re: Hour Meter Reseting
11/30/2007 10:46 AM
I do this kind of thing on Micrologix systems by using a relatively short interval timer to increment locations in a data file. That way, all you lose is the unexpired time in the timer when the power went down.
You have to be careful with the interval - because of the uncertainty in the start/stop time, you can lose (or is it gain?) a few milliseconds at each tick. By a bit of experimenting, you can adjust for that. I have timers measuring 10 hrs ± about 2 sec.
Send me a private mail if you want more info.
There's probably a way to use the RTO (retentive timer) instruction, but I've not played with it.
11/30/2007 5:28 PM
I never lost anything with battery back-up. What am I missing here?
James
" adapt, improvise, overcome "
11/30/2007 6:01 PM
In AB speak, most types of timer & counter instruction reset the accumulator when you power down.
As I kinda suggested, stashing the current time or count in "ordinary" memory (which is retentive) ensures that it's saved; also there is a retentive timer instruction which doesn't reset over power cycling.
Register to Reply 3 comments
You might be interested in: IC Timers
