Previous in Forum: Weighing some large vehicles.   Next in Forum: used oil
lift pump capacity calculations.
11/30/2007 4:49 PM
moving liquids using air pressure and flow.How to calculate the needed cfm of air and at what pressure, if I want to have 30cfm of the liquid flow at the nozzle tip?
Good Answers: 97
Re: lift pump capacity calculations.
11/30/2007 6:02 PM
Do you intend to use a venturi effect pump?.
You have to give us more detail.
12/01/2007 12:05 PM
I intend to use a stadard air compressor, blowing air under pressure over a fluid, lets say, lubricant oil,contained in an oil drum.My problem is how to size the air compressor, that is, the cfm amount at what pressure, in order to get , lets say again, 30cfm of lubricant oil at the nozzle tip.
12/01/2007 2:17 AM
This is injection pump, is not this?
What is liquid?
What is the heigh from liquid surface to nozzle tip?
Nature is unlimited, human's knowledge is limited
12/01/2007 3:15 AM
This is billed as an answer to your question - http://www.sanitaire.com/pdf/techinfo/airlift.pdf
Register to Reply 4 comments
Anonymous Poster (1); clear blue (1); Hendrik (1); nam70 (1)
