I have a couple of questions when it comes to wiring large amounts of LEDs.
1. When wiring in series or parallel (or a combination of the two), where does the resistor need to be placed? I have two diagrams showing opposite placements. One puts the resistor on the positive line before it connects to the LEDs and the other puts the resistor on the negative line after connecting all the LEDs but before going back to the battery. I made a purely parallel circuit using 10 LEDs (i've recently learned not to use purely parallel) and put the resistor on the negative line after connecting the LEDs but before connecting to the battery and the circuit worked fine just have not tried it the other way around.
2. I used blue LEDs to set up a simple series circuit. These LEDs use 3.0 forward voltage and have a rating of 20-30mA... So with 3 LEDs wired in series each LED is getting the appropriate 3volts each. But how many mA are they getting?!
The reason why I ask question 2 is because I am currently working on installing leds into my guitar to run off a 9v battery, the best way after studying to wire them would be a combo of series and parralel. Seeing how they are going into a guitar I dont have a lot of room, so if i can avoid resistors that will make the project a million times easier. While i know hooking up 3 3v LEDs works, i have yet to try and to a combo of series and parallel to get up to my desired amount of 22 LEDs (yeah i know ill have to use at least one resistor for the last single led but i really dont want any more!).
Now using this calculator http://ledcalc.com/ I have been able to figure out how many mA/hr the circuit uses whether its a series or parallel. And to figure out how much a combo circuit uses i know you take one of the series in your circuit (say it uses 20 Ma/hr) and multiply it by how many other series you have in that circuit to get the total consumption. But using my series with no resistor I have no way of knowing how many mA/hr the circuit is consuming and therefore cannot predict how much a circuit comprised of many series with no resistors paralleled together would use.
TO SUM IT UP:
1. Does it matter where the resistor is placed in the circuit?
2. Would my circuit work without resistors as I explained above and if so how much mA/hr would the circuit consume?
3. Would anyone be able to explain to me the best way to wire up 22 LEDs (say using 3.0 forward voltage 20-30mA capacity Blue LEDs and perhaps maybe using 1.9 forward voltage 20-30mA capacity Red LEDs, oh yeah and using a 9v battery source)
4. I read somewhere about increasing voltage, this could be pretty helpful if I could say double the voltage of the battery to 18 volts thereby allowing me to use more bulbs in each series thereby reducing the amount of series i need paralleled and thereby reducing the overall mA/hr used.... Of course I have no idea how to do it or if its even possible, any suggestions?
I've been searching the net for the past two weeks constantly reading up on a lot of different circuitry diagrams and things of that sort but I am having some problems digesting how to set this up correctly and what exactly is possible.. Hell it wasn't until today that I found out I shouldn't be using strictly parallel for wiring leds and that by using a combo of series and parallel you can light up the same amount of leds using much less mA/hr along with a ton of other reasons on why its bad to do just parallel. So I have come here in hopes to get some answers to questions I just havn't been able to find the answers to after endless searching.
