I am doing die casting for my customer by his print in China.The print require the casting to be painted.and the specification as following:
Notes:
1. NO DOUBLE PAINTING WILL BE ACCEPTALBE.
2.FIXTURING THE RING FOR PAINTING:EXTERNAL BLEMISHES ARE UNACCEPTABLE
3.COMPLETE COVERAGE INSIDE AND OUTSIDE
4.PAINT:FULLER O BRIEN CORP. NO. EFB-40B-53(PRIMARY) BLACK EPOXY
FULLER O BRIEN CORP. NO. EFB-504-50(ALT.) BLACK EPOXY
5.DO NOT USE SILICONE SPRAY AS A RELEASE AGENT IN THE DIE CASTING PROCESS
6. .001/.002 thickness
1.Is there anybody can tell me what the item 1 means?Why double painting?
2.it require no external blemishes,so we will fix inside to painting.
4. Is there anyone can tell me the performance of the FULLER PAINTING?I can not get it by google.
5.What the item five means?why silicone spray?
In addition,according to above specification,anyone can tell me powder painting or spray painting is better?
Because I do cast and machining,so I am not very clear about painting.
Cast,Forge,Weld,Machining,Screw,Nuts,Valve,Pump
