Previous in Forum: What Is FEA?   Next in Forum: Can RH Be >100% In The Return Air Duct??
Induction Hardening
12/06/2007 11:38 AM
I am working in INDUCTIO HARDNING basically i am a Mechanical engineer, SG IRON shaft i will got crack after Induction process Over.pls help how to solve this problem , i am using polymer, Edge crack, how yo solve this problem,give me a tips for induction hardning,
Re: INDUCTION HARDNING
12/06/2007 2:30 PM
Could you please check your grammar with a colleague, as its difficult to know what you are asking.
A lot more detail may be required to understand your problem, I gather that a iron shaft you're hardening is cracking after heating? It may help to know the shape of this shaft?
John.
Re: Induction Hardening
12/12/2007 10:05 AM
May be it is because of overheating. Please check the case thickness requirement & the actual being achieved with the heating & quenching cycle you are using. Also indicate the frequency/power rating , AISI code of shaft material, shape , whether any predrilled holes are present in the area to be hardened etc.
You might be interested in: Induction Heaters, AC Motors, Flaw Detectors
