Previous in Forum: New high speed engine?   Next in Forum: Steam Drum PSV Inlet losses
12 comments
Good Answers: 25
Function of fuel vapor recycling [?] fitting for small gasoline engine
12/24/2021 5:45 AM
I acquired a small gasoline-powered genset unit from a friend, who as it turned out had neglected it for some time. I worked on it, hoping to get it working during the seven-day power outage that followed the passage of typhoon "Odette." I have (I think) solved most of the problems, but here is a weird one. There is a fitting on top of the fuel tank that connects via a flexible tube to an auxiliary input on the air cleaner, so naturally I thought it was to take fuel vapor and feed it to the engine intake, rather than dissipating it in the atmosphere. But as I discovered when I drained the tank of fuel in order to de-rust it, the fuel filler forms a gas-tight seal, so another function of the fitting must be to break the vacuum above the fuel in order to allow it to flow.
But here's the thing - it doesn't seem to pass gas in either direction.
Before I chisel the damn' thing off and start over, I would like to be sure of what it is supposed to do.
The fitting belongs to a Coleman Powermate 3000 genset, and to anticipate early comments, I have tried to find a service manual on line, with no success.
Re: Function of fuel vapor recycling [?] fitting for small gasoline engine
12/24/2021 6:48 AM
I believe that is the rollover valve connection...supposedly shuts off gas if the generator becomes inverted somehow...
Good Answers: 25
12/24/2021 11:15 PM
The arrow does point to the fitting that I am talking about, but how does it turn off the fuel? The hose connects to the air cleaner at the other end, and there is no electrical wiring connected with it.
12/25/2021 2:26 AM
It's a simple ball and float setup, I suspect the ball has been stuck with gasoline residue in the closed position, maybe some carburetor cleaner would free it up....or possibly a generic replacement, as the part is discontinued....
Good Answers: 25
12/25/2021 9:16 AM
Sounds like a good lead. I will spray carburetor cleaner into the thing tomorrow and see what happens.
Good Answers: 25
12/30/2021 11:34 PM
No result with carburetor cleaner, no effect when trying to force air through the valve using my tire compressor. Next step is to drill out the blockage, then figure out the best way to fit a conventional breather.
12/24/2021 11:16 PM
I have a vaguely similar unit (Firman 3600W), and without close examination, the Filler Cap on it also appears to form a gas-tight seal. Since you've brought it to my attention, I'm going to have to investigate how air gets into the fuel tank, but that will wait 'till daylight...
Again, without close examination, I don't see any comparable hose/connection to the top of the tank. This makes me suspect that SE gave the right answer, and mine does not have such rollover protection.
12/24/2021 11:18 PM
https://www.ereplacementparts.com/powermate-pm0103008-3000-watt-portable-generator-parts-c-117046_130613_327647.html
12/24/2021 11:58 PM
Not shown, but present, and obsolete, is Hose, fuel vapor, so I suspect that your vapor vent port is plugged with rust. My Coleman 4000W machine is from 1980s, fuel cap has a pinhole in it, and no vapor vent. I was able to order a replacement tank for it a few years ago, also all rusted, so shouldn’t be a problem. Or change the cap.
Good Answers: 25
12/25/2021 9:23 PM
So, last resort - drill a small-diameter hole through the filler cap.
Good Answers: 25
12/25/2021 9:22 PM
And, sure enough, part 29 which is the one I'm looking at is called "valve, rollover." Damn' I love this forum.
12/25/2021 4:37 AM
Maybe it is a breather for the tank to allow filtered air into the tank.
Stihl use a similar idea on their 2 stroke motors, but there the really fine sawdust gets into the fuel tank, good idea bad execution.
Hare today, goon tomorrow!
Good Answers: 25
12/25/2021 9:25 PM
Funny how working on one piece of equipment reveals problems with others. I wanted to use my compressor (used mainly for inflating tires) to try to force air through the rollover valve. And the power cord is missing, and of course it's a custom type, not an ordinary power cord or extension cord.
It's here somewhere.
Register to Reply 12 comments
dkwarner (1); Haymaker (1); piolenc (6); rwilliams (1); SolarEagle (2); Stef (1)
