Previous in Forum: 11 kV Busbar current rating.   Next in Forum: Soft Starter
10 comments
Transformers for illumination
01/22/2022 8:54 AM
Dear Sirs,
Do we need transformers for illumination, as for valve house and surgetank site of hyropowerplant in around 63kVA transformer?
We also had around 1000 kVA of isolation transformer intended for headworks.
Regards,
Re: transformers for illumination.
01/22/2022 10:06 AM
If you can find an 11kV light bulb, then no, you don't need a transformer.
Good Answers: 804
02/08/2022 4:47 AM
Arc lighting perhaps?
01/22/2022 11:09 PM
"Do we need transformers for illumination"
Tornado's answer is correct.
"transformers" is plural. You may be able to make it work with just one, but you MUST have an appropriate voltage for the lighting devices selected.
Good Answers: 22
01/23/2022 1:14 AM
If your LV switchgear is 3-pole design without neutral busbar, then you need an isolation transformer to obtain a neutral for single phase distribution to lights and socket outlets.
The isolation transformer has another benefit as well that it reduces the fault rating in the lighting / small power circuits, thus allowing one to employ MCBs (without need for HRC fuses) in the DBs.
Raghunath
01/23/2022 6:35 AM
https://www.electrical4u.net/electrical/purpose-of-unit-auxiliary-transformer-uat/
If you have an auxiliary Tfx, use that for small power and lighting.
Re: Transformers for illumination
01/24/2022 7:16 AM
If the site is never to be accessed during periods of low ambient light, then no, and the <...we...> doesn't need lighting installations either.
Local Health & Safety regulation determines this more than anything else.
The end Client may well have a requirement.
01/24/2022 7:47 AM
It is getting difficult to sort out which <...Anonymous Poster #1...> is which these days...
Anonymous Poster #2
01/24/2022 8:12 AM
Retsop Suosmynona
01/24/2022 10:29 AM
Gesundheit.
Reply Off Topic (Score 4)
02/01/2022 5:02 PM
You generally don't need an additional separate transformer just to power the lights (which I am assuming is what you are asking about), you should have spare capacity in your supply or auxiliary transformer for lighting.
Anonymous Poster (1); dkwarner (1); IQ (1); jack of all trades (1); JRaef (1); PWSlack (3); raghun (1); Tornado (1)
