Previous in Forum: LOAD COMBINATION/ STRESS COMBINATION   Next in Forum: API 650 Tank, Annular Plate Width Cal.
14 comments
API 650 Tank pressure
02/03/2022 1:37 AM
Hi!
Greetings to all
In API 650 Code given internal pressure limit of 18 Kpag (2.5 PSIG)., Can someone explain me is this pressure above the liquid level of tank fluid because if we consider design pressure including liquid head then pressure 18 Kpag will be exceeded.
Thanks.
Re: API 650 TANK
02/03/2022 4:50 AM
You need to know the difference between operating pressure, set pressure, overpressure, design pressure and accumulation.....Just read the code...this would be for an atmospheric pressure tank...
"Design pressure for a vessel is taken by adding a suitable margin to the maximum possible pressure during normal operation.
The maximum allowable working pressure is the highest pressure that the vessel can withstand based on actual nominal vessel thickness excluding the allowances provided for corrosion and loadings other than pressure.
Set pressure of a relieving device on a pressure vessel is the pressure when the relieving device just starts to open."....
https://www.enggcyclopedia.com/2011/06/key-terminology-relief-devices-vessels/
Location: 3rd rock from the sun,a small dust mote,in a small insignificant spiral galaxy referred to locally as the Milky Way
Re: API 650 TANK
02/03/2022 8:01 AM
PSIG means Gauge pressure,as opposed to PSIA,which is Absolute pressure,which is referenced to a perfect vacuum.
Atmospheric pressure surrounds the outside of the vessel,as well as inside,so for all intents it can be ignored.
There is no darkness except for ignorance..Shakespeare
Re: API 650 TANK
02/03/2022 11:17 PM
Thanks
Re: API 650 TANK
02/04/2022 1:22 AM
THANKS SIR
Re: API 650 TANK
02/04/2022 12:32 AM
The tank, if designed for liquid, would need to be designed for the load of the liquid, vented or not. The forces at the bottom wall would be the weight of the liquid plus the absolute pressure on the top. The tank pressure above the liquid would be added to the liquid head to arrive at the bottom wall stress, so some 17.2 psia, in your case.
Re: API 650 TANK
02/04/2022 7:31 AM
If vented to atmosphere,the head pressure is the only factor to consider,not absolute pressure.Atmospheric pressure is the same in all directions.
Good Answers: 137
Re: API 650 TANK
02/04/2022 10:23 AM
I don't think that's right. The forces at the bottom wall would be determined by the height of the liquid (and its density) plus the gauge pressure in the gas space. The outside of the tank also sees atmospheric pressure.
It's not unusual to have thicker plates at the bottom, getting thinner towards the top, especially with bolted sectional tanks.
Re: API 650 TANK
02/04/2022 10:05 AM
Then it isn't a <...tank...>; it's a "pressure vessel" instead, and a different design code may be needed.
It is, however, impossible to see what's going on without access to a P&ID.
Good Answers: 137
Re: API 650 TANK
02/04/2022 10:32 AM
2.5 psig is the maximum pressure in the gas space allowed by API 650 (assuming you've quoted it correctly, I haven't used it recently and don't have it to hand). You need to add that to the liquid pressure to determine the plate thickness. I'm fairly sure 2.5 psig is the maximum allowed, if the pressure is lower you can use the actual figure. Also I believe API 650 only applies to circular tanks.
Good Answers: 38
Re: API 650 TANK
02/04/2022 5:18 PM
Agree with Codemaster .... API-650 addresses flat bottomed tanks and states that if you use the design methods and acceptable materials and construction methods outlined in this code, you can use these rules for a maximum pressure in the gas space of 2.5 psig.....
Contrast this with API-620, which has slightly different design rules, can be used for flat bottomed tanks and permits design to a slightly higher maximum gas space pressure.
Re: API 650 Tank pressure
02/08/2022 9:51 AM
The phrase <...we consider...> suggests that there is a Mentor available at that location. Good design practice is to get a second-person-check on designs before obtaining commercial approval. Discuss the project with that individual.
Good Answers: 137
02/08/2022 11:19 AM
Perhaps the OP will confirm, but I doubt if the "we" in because "if we consider design pressure including liquid head....." refers to a specific person, it's just another way of saying "if design pressure including liquid head is considered....".
He just wanted clarification whether the 2.5 psig is the gas pressure alone or includes liquid head, and that's been done.
02/09/2022 8:29 AM
Quite.
That's the problem with undefined plural pronouns. What hasn't been done here, though, is a second-person-check as part of a design procedure. After all, no reader here is liable if construction comes out wrong and it has to be redone.
Good Answers: 137
02/09/2022 9:09 AM
I think he just wanted to clarify a technical point. There's no need for CR4 to get involved in the process aspects which produce those conditions, or any contractual issues he might have.
akash.t (2); Codemaster (4); hitekrednek2 (2); MJCronin (1); PWSlack (3); rwilliams (1); SolarEagle (1)
